Up to 20% off select tools
14 Megapixel camera. Has 12x Optical zoom, 48x Digital zoom, OIS, HD video with Stereo microphones and autofocus. Comes in Red or Black. This camera supports the following memory cards: SD/SDHC/SDXC/EyeFi (full support).
My flash does not work
why doesn't my flash work?
1 Comment
Had same problem. Cleaning and reset did not work. Saw there was a small gap in the case in top left corner. When holding to shoot a picture I squeezed down with left pointer finger on top of camera and suddenly it recognized that the flash was raised.
by Share
Add a comment
1 Answer
Chosen Solution
Does it not work as in not fire, or not pop up?
If it doesn't pop up, there could be debris preventing it from working correctly. Check for debris and if you find any, clear it out with a soft cloth or toothpick or even a soft bristle toothbrush.
Also, if it isn't popping up correctly, it could be that the spring attached to the flash has either broken or come loose.
If the flash isn't firing then the bulb could be out.
Also, you should be able to go into the settings on the camera to make sure the flash is turned on, or that it is dark enough where you are trying to take a picture for the flash to actually fire.
Check out the troubleshooting guide for more information.
Add a comment
Add your answer
Joe Henry Smith will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 36
All Time: 1,496
