Up to 20% off select tools
ASUS P53E-Series Notebook repair guide which gives step-by-step instructions and troubleshooting tips for common hardware and software issues, ensuring optimal device performance and longevity. Users can diagnose and fix issues with their P53E laptop with this comprehensive resource.
Instructions to replace the keyboard?
I have looked all over for the correct answer with no luck. I need the instructions on how to remove the Asus P53E keyboard for replacement.
Score 1
Add a comment
1 Answer
Most Helpful Answer
Most Asus laptop keyboards are easily removed by pushing in the retainer clips near the top of the keyboard where it meets the bezel. Use a small spudger or tool to press the clips in then lift that section out, and continue on until all clips have been removed. After that, it's even more straightforward, remove the flex from the ZIF connector and reverse those steps.
Apologies that I do not have any instructions to link you to but it is really a quick and simple repair. If you're having trouble, I'm sure you can find a video on youtube.
Score 2
Add a comment
Add your answer
Bill Lockie will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 22
All Time: 1,107
