Tefal Actifry - Convection Cooker. First launched in 2006, this revolutionary, versatile fryer allows you to cook a wide range of meals economically and its also safer and easier to clean than other fryers
Replacing the heating ellement
Replacing the heating ellement in a Tefal Actifry
Score 4
1 Comment:
The paddle stopped turning on mine and after fitting a replacement motor the heater and fan did not work but the paddle did. After careful examination of the circuit board I noticed that the larger of the two fuses had blown. It looks like an antisurge fuse and it was very difficult to see if it was blown but my meter confirmed it was U/S. Unfortunately the fuse needs to be desoldered and a replacement soldered back onto the circuit board. All good afterwards. Tefal need to think about their philosophy and try to make stuff that lasts longer than 12 months and is also easier to repair.
by
Add a comment
1 Answer
follow the guide for the paddle motor, the heatin element module can be prised out gently using a screwdriver and the 2 black leads removed from the PCB board.
Add a comment
Add your answer
Mike will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 25
All Time: 4,163
