Up to 20% off select tools
The HP Compaq nc6400 is a thin and lightweight 14.1” laptop in HP’s business line. The device was released in May 2006.
Window Vista installation error message
This is the error message that l get when l try to instal window
Non-system disk or disk error
Replace and strike any key when ready
Please what can l do?
2 Comments:
in which part of installation you have this error ?
by Share
Just. Turned on computer and this message was on here
by Share
Add a comment
1 Answer
Ok bud. So this is when the bios can not find the operating system. This could be an easy fix! Go into your bios settings, which should pop on when turning on the computer. Maybe F9? F12? One of those. Go into your Boot settings, look it up if needed. And change the hdd that starts on boot.<—- Look that up if you need to know how. “Change hdd that starts on boot” or along the lines. It may not have one OR you have two hdd’s in there and it doesn’t know which one to boot off, so you just switch it.
If that doesn’t work, you may need to reinstall Windows XP. But before that, try what I said.
Add a comment
Add your answer
Franklin will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 27
All Time: 444
