The HP Photosmart Premium All-in-One printer can be used as a printer, copier, scanner. This printer uses a 5 color print system.
How can I improve the quality of printing?
The quality of the image is not acceptable. How Can I improve the quality? I made sure the ink cartridge levels are good.
Score 1
Add a comment
1 Answer
Chosen Solution
I would recommend checking the levels of the ink to be your first step. If they appear to be fine then you may need to replace the printhead. You can see our guide on how to replace the printhead.
If your levels of ink are low you should replace the ink cartridges which is also shown in our guide.
Score 2
1 Comment:
You could also clean the printer head as the printer head can get clogged with gunk. Google "how to clean printer head" and go from there.
by
Add a comment
Add your answer
Laura will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 14
All Time: 496
