Up to 20% off select tools
A solar powered lantern designed by Sun King.
How do I replace a Burnt Out LED?
Only some of the LED's light up, how do I replace the ones that do not work?
Score 1
Add a comment
1 Answer
Most Helpful Answer
The LED's can be tricky to replace. In order to replace an LED you will need to separate the circuit board containing the LED from the rest of the device. Using wire cutters, you will need to clip the broken bulb off and then solder a new one into place. The link below will take you to a soldering guide.
Soldering
Score 1
Add a comment
Add your answer
Josef Simek will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 41
All Time: 1,591
