The Planet Eclipse Etha is a mid-range electronic paintball marker released in October 2011. It offers a lower-cost alternative to one of Planet Eclipse's most popular paintball guns, the Geo.
How Do I Fix a Leaking Solenoid?
My Etha is leaking from the solenoid. How do I fix this?
Score 3
Add a comment
1 Answer
Most Helpful Answer
There are two common causes. First, turn the pressure on the regulator down and check for leaks again. If the output pressure of the regulator is too high, the solenoid may not be able to handle the extra pressure. If it still leaks, you will most likely need a replacement solenoid. These can be ordered from Planet Eclipse, or your local field might have one. Once you have a new solenoid, we have a replacement guide for you here.
Score 1
2 Comments:
Hay all I have a vibe marker and the solenoid has exploded is there anywhere I can get another 1 from and I am in Western Australia cheers
by
Mine don't hav a gauge on it
by
Add a comment
Add your answer
Evan Hench will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 31
All Time: 3,062
