A cordless power drill that has rechargeable batteries. Model No: Skil X-Drive 18V Cordless Drill Model No. 2887
My chuck is not spinning?
Everytime I press the trigger the chuck does not spin, the battery has power, for your information. What possible things could be wrong with my drill?
Add a comment
Chosen Solution
I had a similar issue. When you pull the trigger the light came on but the chuck would not turn. No sound or smell, the chuck just didn't engage. When I took it apart I found there was a cold solder joint on the red lead to the motor which came loose.
Score 1
Add a comment
The trigger switch may be bad. It might also be a bad motor or a wiring problem.
Add a comment
Add your answer
Sean will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 32
All Time: 2,014
