The Canon EOS 300D is a 6.3-megapixel entry-level digital single-lens reflex camera.
Why is only half an image showing?
only a portion of the image appears when I take a picture
Add a comment
Chosen Solution
Is the image messed up on the LCD screen or within the saved picture? If the LCD is only half viewable then the LCD display is damaged. If the saved image is cut off is it on the bottom half of the image the reflex mirror is not working correctly and will need repair.
Score 2
Add a comment
probablement le ressort coté miroir est brisé j'ai le même problème sur le mien et j'aimerais savoir comment le remettre en place merci
Probably the spring mirror side is broken I have the same problem on mine and I would like to know how to put it back thanks
1 Comment:
There are a few elements involved here. The mirror, the mirror's hinge, the foam cushion at the top (were the mirror hits). The control levers within the mirror control mechanism. And lastly, dirt or a spilled drink or dried out lubrication.
You will need to analyze what is the cause. try to engage the mirror lock up to see if the mirror goes up, you may need to carefully lift the mirror as well and if it sticks at the top carefully pull it down. Use very little pressure otherwise you can break things!
Il y a quelques éléments impliqués ici. Le miroir, la charnière du miroir, le coussin en mousse au sommet (si le miroir frappe). Les leviers de commande dans le mécanisme de commande miroir. Et enfin, la saleté ou une boisson déversée ou la lubrification séchée.
Vous devrez analyser quelle est la cause. Essayez d'engager le verrouillage du miroir pour voir si le miroir augmente, vous devrez peut-être soulever soigneusement le miroir aussi et si vous vous trouvez en haut, retirez-le avec précaution. Utilisez très peu de pression sinon vous pouvez casser les choses!
by
Add a comment
Add your answer
Kay will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 23
All Time: 1,496
