Up to 20% off select tools
The Jeep Grand Cherokee was redesigned for the 1999 model year; the 2000 models have minimal changes. This model is also known as Jeep WJ.
replace driver side door actuator
Get a screeching sound when activating electric door lock. Assume gear strip in the actuator but pulling the door apart with connecting rods etc is beyond my current knowledge.
Score 3
Add a comment
1 Answer
Chosen Solution
tom quiggle, follow this video to replace the door panel. then follow the manual:"
(2) Remove screws attaching door latch to door
(3) Disconnect all rods from door latch.
(4) Disconnect wire harness connector, if equipped.
(5) Separate door latch from door
Hope this helps, good luck.
Score 1
Add a comment
Add your answer
tom quiggle will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 24
All Time: 7,061
