The 7 inch third generation of Nook color tablets by Barnes & Noble, not to be confused with the 9 inch Nook HD+.
Need a source for replacement battery.
I have searched for a replacement battery for the Nook HD to no avail. All that can be found are not for the HD. None have the 4000MHA, 14.8 Wh rating.
Does any one know of a source, other than B&N (who won't sell the battery) ?
Score 1
Add a comment
Most Helpful Answer
jmbiii3, the battery number for your Nook HD is BNA-B0002. the battery appears to be available right here and here as well. Of course, always check with the vendor. If you are truly fixed on the 4000mAh you can check on here
Score 1
1 Comment:
Thanks ! The battery in the HD is a 4000mAh and I would like to keep it at that rating. I'd order the one you mentioned last, but can't quite read the order info. LOL
by
Add a comment
Here you go!
https://www.newpower99.com/SearchResults...
Add a comment
Add your answer
jmbiii3 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 2,529
