booting from usb external drive
Trying to fix my old PowerBook G4. I found my internal hard drive is dead.
I'm trying to reinstall the Mac OS-X but doesn't find any drives.
I attached an external USB drive (to try to install the software there) but doesn't find it. When I open disk repair, the external drive is there (the internal drive doesn't show)...
Any suggestions? Can I install the operating system in the external USB and boot from there?
Thanks!
David
Score -1
1 Comment
Can you give us the OS-X version you are trying to install.
by
Add a comment
Most Helpful Answer
Sadly you'll need a FireWire HD which has the older OS's this system uses, either OS-9 or OS-X 10.5.8.
Your other option is to boot off of the grey OS installer disks that came with the system or a retail copy of either of the OS's I've listed here.
Score 2
Add a comment
If your internal drive is dead it likely needs replacing. Have you done that yet?
Sadly, you can't boot up the older PowerPC based systems (G series) under a USB drive, you need to use a FireWire connected drive and the drive needs to have a bootable OS on it for your system.
Depending on the OS version you are working with here you may need an older version or use a boot disk that was created on a G series system as the earlier versions of OS-X had two installs one for PowerPC based systems and the other for Intel based systems.
Score 1
Add a comment
Google told me, if any, it can only boot via a firewire harddrive, because it is a notebook before intel or sth like that. Just google it
Add a comment
Just put your new disk into the g4 and make a normal install it from your macosx dvd...
Pd.- if you cant give us more specific details we cant give you more specific solutions
Add a comment
Add your answer
david will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 14
All Time: 1,921
