Up to 20% off select tools
The first of the new generation Nokia devices – the first with a 1080p screen, the first with a quad-core Krait processor
Instructions for replacing glass
HI,
Would you or anyone know a good link for instructions on how to replace the glass only on a Nokia Lumia 1520?
Thank you
Score 3
Add a comment
Most Helpful Answer
Here's a video on replacing the digitizer: http://forums.wpcentral.com/nokia-lumia-...
Score 2
1 Comment:
Hi,
Yeah, I saw that. But the videos are for the 1020 and 520. They are not the same... not even close.
by Share
Add a comment
Hi,
The Nokia Lumia 1520 display is glued to the digitizer and glass. Also it has an unusual rubber frame around it. Except for the rubber frame it's the same procedure as for every other glued display assembly.
However I don't know if you need LOCA/OCA in order to install the new glass. If you do then you need the proper equipment and skill.
Score 2
Add a comment
Found this video helpful when I took mine apart.
https://www.youtube.com/watch?v=LsVukgH0...
Add a comment
Can someone help, I replaced mine just five days ago, now the screen is flicking with the back button always executing commands, Cortana opening up on it own or the phone just freezes when scrolling, I have to lock and unlock the screen to go back to normal, it is even getting to a point I sometimes can't end my own phone calls. What I can do..
Add a comment
This looks really hard. I looked at the nokia lumia 1320 lcd replacement.
https://www.youtube.com/watch?v=ByvqnMWN...
Might be helpful but it is not the 1520...
Add a comment
Add your answer
Kevin will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 17
All Time: 10,791
