The HTC One SV is a sleek 4G LTE capable Android smartphone that combines great sounding Beats Audioâ„¢
Why does an error message keep popping up?
An error message saying my dialer has stopped working keeps popping up. It gives you an option of send a report or don't send and it pops right back up after you pick one of the options.
I had my carrier factory reset it and it did not help. Please help save my phone.
Score 6
Add a comment
The issue you are seeing is call "force closing".
If your phone is stock, that is not rooted, then chances are a third party app is causing the problem. If it happens after a factory restore, with no third party apps installed, then you just need to clear the cache.
http://forums.androidcentral.com/verizon...
That's a guide on clearing your cache. You will have to redownload your apps but that should fix it.
2 Comments:
i cant clear my cache in htc one m8 due to marshmallow update
by
? Marshmallow has nothing to do with the stock recovery. You absolutely can still clear your cache after the update.
by
Add a comment
Go to settings then go to apps after that go to running apps and uninstall up date on input sense
Add a comment
I am experiencing the same issues with many apps. Email, clock, dialer etc. I am unable to get into settings.
Same error.
What other options are there?
Add a comment
SOFTWARE updating problem
Add a comment
Add your answer
Nicole Hallett will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 23
All Time: 11,026
