The Sony Ericsson Xperia Arc S is a phone with Android 2.3.4 featuring a a 1.4 GHz Snapdragon CPU and 14.4Mbit/s HSDPA.
Cannot turn on device, charging or not
When I press the power button, the unit sometimes can be turned on, sometimes not.
Recently, it is totally dead. Even I have a fully charged battery or connecting to a USB cable, the unit has no response to the power button.
No red light when I charge the unit as well, i.e. the unit won't charge.
Score 5
Add a comment
1 Answer
Most Helpful Answer
Hi,
If the battery voltage is OK then clean the battery connectors. Check what happens when you connect it to the PC. Connect the device until you hold the Back key (down left key). If the windows see the device in the "Device manager" then may be you have a software problem.
Try a Hard reset. Press and hold left and right buttons under the screen. Press and release the Power button. Follow the instruction for a hard / factory reset.
!!! This will erase all your data !!!
Next, you can try SW update with the PC Companion or directly with the Sony Update Service.
If you haven't reaction from the windows for connected device then yo have a hardware problem.
Regards.
Score 3
2 Comments:
Thank you very much for your advice. It is very appreciated.
device manager cannot see the device. guess it is hardware problem. anything i can do?
by
No, you need a mobile phone specialist :(
by
Add a comment
Add your answer
Peter will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 37
All Time: 7,976
