Improved second generation Google-branded tablet with a 7" screen.
Can I upgrade my storage?
Is it possible to upgrade my 16GB 2013 Nexus 7 storage to a 32 GB or more? Sadly the operating system takes up more storage space than I expected (a whole four gigs!) so now I only have 112 gigs of usable space, and I need a little more for what I use my tablet for. Any help at all would be appreciated, thank you in advance!
Score 2
Add a comment
Most Helpful Answer
Hi,
You can't do this. No way to change or upgrade internal memory. This memory (i.c. chips) are soldered to the mother board.
Regards.
Score 3
Add a comment
the other option is to see if you can buy the motherboard on ebay with 32 or 64GB and swap out your current with the new motherboard containing more space
Score 1
Add a comment
You can't add more internal storage, but you could add some external storage. There are new flash drives that plug into the micro-usb port and also plug into a PC's usb port (but only one at a time.) They're called USB-OTG (On The Go) drives.
1 Comment:
How does that work? Just a cable to connect to computer and then use tablet while connected.or is there a drive also that is portable?
by
Add a comment
Yes its possible. Just go to settings, internal storage and click upgrade storage to 32 gb, 64gb or 128gb.
1 Comment:
Hi Abraham,
Were you thinking of another model perhaps?
I have the Nexus 7 2nd Generation and unfortunately you can't upgrade its storage.
by
Add a comment
Add your answer
Jacob will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 22
All Time: 12,481
