Repair guides and support for the LeapFrog LeapPad2 Explorer 32610 learning tablet.
Why is there no sound?
The volume is up fully and will not produce any noise! Help!
Score 1
4 Comments
What is the exact model of phone you have? That way I will be able to further help you know what the exact problem is with your phone.
by
@computeripodrepair, LeapFrog LeapPad2 Explorer is a childrens learning tablet, not a phone!
by
Andrew Gough, what have you tried so far? how long has this been going on? Has anything happened just prior to it failing?
by
My daughter own is the same problem no sound
by
Add a comment
1 Answer
Most Helpful Answer
You might have a bad speaker or audio jack. In the case of the speaker you would need to check the connection between the speaker and motherboard. If it was due to the audio jack, cleaning it with an air duster may help. Check out the Troubleshooting page if you any issues.
Score 2
Add a comment
Add your answer
Andrew Gough will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 45
All Time: 7,145
