The Skullcandy Skullcrushers Subwoofer Stereo Headphones in Black Pinstripe will literally pump the music right into your head! These power packing headphones feature an adjustable in-line bass amplifier and speakers with industry first built-in vibrating subwoofers. You can adjust the amount of bass effect with the in-line control wheel.
How to fix or replace headphone Jack?
I own a Skullcandy Skullcrushers head phone that has recently had problems with the jack of the unit.
The issue is where only the left ear speaker functions properly at all times while the right is silent unless the wire on the jack is moved to a "Sweet Spot" where functionality returns until the wire is moved from the new position.
My question is weather or not it is possible to fix or if not, replace the jack all together. What would be required to replace the jack and what wire placements are for the left and right ear respectively.
Score 1
Add a comment
1 Answer
Chosen Solution
abyssalshaman, yes it is. Check this guide on how to replace the jack. This is a good set of headphones and relatively easy to repair. Hope this helps, good luck.
Score 2
1 Comment:
Thanks so much Oldturkey03! I love these headphones and would rather replace the jack for a fraction of the price it takes to buy a new set haha :)
by
Add a comment
Add your answer
abyssalshaman will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 29
All Time: 3,029
