An Acer Aspire 5100 Laptop with a 15.4" inch display.
My fan is not working
the old cooler start when bios start then goes off after the boot, and now i change to a new one but the same it start in bios but after the boot it goes off
it is fan socket problem or some transistor dont give power to the fan?
Score -1
1 Comment
see if you can post two high res images of your logic board (front and back) Acer uses a APL5607 as a fan controller. It might be possible to check that out.
by
Add a comment
1 Answer
Most Helpful Answer
if you know how to disassemble your laptop then you can see if the fan is just dirty or disassemble the fan and clean it.if it not work change the fan.
Score 1
1 Comment:
@serafin garcia, "now i change to a new one" shows you the importance of reading the question before trying to answer.
by
Add a comment
Add your answer
lidia muraru will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 15
All Time: 484
