The Time Capsule Model A1302 is the second generation of Apple's wireless router and networked storage device released in March 2009. Most information from these repair and disassembly guides also applies to the original Model A1254.
Time capsule hard drive replacement software
If I install a new hard drive in my time capsule, when I power the device up will it boot normally? I recently replaced the hard drive in my MacBook pro and had to jump through several rings of fire to get it working again. I am debating about just buying a new time capsule instead of trying to upgrade the broken disk.
Score 1
Add a comment
1 Answer
Chosen Solution
Time Capsules use a different format than a Mac system. So don't bother trying to configure it off of your system.
Once you put in the new disk in, use Apple's AirPort Utility to setup the disk.
Score 3
Add a comment
Add your answer
Peter will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 23
All Time: 1,832
