Released June 2009 / 2.66, 2.8, or 3.06 GHz Core 2 Duo Processor
Location of the WLED driver
Can someone tell me where the WLED driver on this Macbook Pro? This is a Macbook Pro 15" 2.8Ghz Mid 2009 EMC 2324. I have also included pictures. Thanks in advance.
I'm sorry, but I couldn't find the last three digits of my serial number.
Score 2
7 Comments
Kevin, not sure where you posted your images:-) use this guide Adding images to an existing answer to post your images with your question. Also, it will help tremendously if you give us the last three digits of your computers serial number.
by
I just uploaded the pictures. Sorry about that.
by
Hey, no problem:-). do these look like the specs for your computer:" 2.53 GHz Core 2 Duo (P8700)
Intro Date: June 8, 2009 Disc Date: April 13, 2010
Order No: MC118LL/A Model No: A1286 (EMC 2324*)
Subfamily: Mid-2009 15" Model ID: MacBookPro5,4
Std RAM: 4 GB Std VRAM: 256 MB
Std Storage: 250 GB (5400 RPM) Std Optical: 8X DL "SuperDrive"
by
No, but I think this is it (mine has a 2.8 Ghz) :
Intro Date: October 14, 2008 Disc Date: March 3, 2009
Order No: BTO/CTO Model No: A1286 (EMC 2255)
Subfamily: Late 2008 Model ID: MacBookPro5,1
Std RAM: 4 GB Std VRAM: 512 MB*
Std Storage: 320 GB (5400 RPM) Std Optical: 8X DL "SuperDrive"
by
Kevin, check the EMC number on image #1 it shows EMC 2324. you sure about the EMC 2255?
by
Show 2 more comments
Add a comment
1 Answer
Chosen Solution
Kevin, for the EMC 2324 as it shows on the images you uploaded, the LCD backlight driver has reference designator U9701. It is a LP8543SQX manufactured by TI. the datsheet is available right here. The part itself seems to be a bit hard to come by, but it is available :-) Hope this helps, good luck.
Score 4
3 Comments:
Thank you very much for your help.
by
where can I get the replacement piece? thanks
by
Add a comment
Add your answer
Kevin will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 13
All Time: 25,264
