The fourth generation Volkswagen Jetta, also called the MK4 or the Bora, is Volkswagen's family sedan.
does not start . how to check why
does not start. what to check to see why
Score 2
Add a comment
1 Answer
Chosen Solution
David,
More info would help to point you in the right direction.
Basically you need Ignition, Compression and Fuel
Compression- Is engine turning over or cranking (battery, connections, starter, relay)
Fuel- Are you getting gas to cylinders (fuel, fuel pump,injectors and sensors)
Ignition- Spark to to cylinders (spark plugs, ignition coil, plug wires and sensors)
Hope this gives you a direction, Glenn
Update
David,
Check this out
https://wiki.bentleypublishers.com/pages...
Glenn
Score 1
1 Comment:
hi Glen > this will be my first time working on one of these cars . No problem turning it over . If there is spark then start at the fuel . What pressure should the fuel be
by
Add a comment
Add your answer
David Borton will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 28
All Time: 1,001
