Repair guides, disassembly, and troubleshooting information for the updated version of the second-generation Apple iPad with Wi-Fi, available with 16, 32, or 64 GB of storage. Released in March 2012. Identified by model number A1395 and EMC 2560. It features a smaller processor die and updated internal construction. Repairs require the use of heat and careful prying.
Camera Shutter Stuck After Screen Replacement
I recently replaced a broken screen and now the back camera shutter is stuck. I tried a new back camera, but that didn't fix it. I also tried a hard reset, but that also didn't work. Ay ideas how to resolve the issue? Could the connection not be right?
Score -1
Add a comment
Chosen Solution
I figured it out. I removed the camera, erased and reset the iPad, ran the set up process, and then reinstalled the camera. Then everything worked.
Add a comment
Most Helpful Answer
Some loose connectors between cameras and the logic board. Reseat every connector in between, especially the front camera which is easy to come off
Score 1
Add a comment
Add your answer
Boss77 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 18
All Time: 519
