The first generation Neon was introduced in January 1994 and manufactured until August 1999. It was available as a four-door notchback sedan and a two-door notchback coupe.
Why wont my engine fire or run?
It will turn over. but it will try to start up on starting fluid. tjen it quits trying to run just turns over. whats wrong??
Score 1
1 Comment:
similar problem on our car turned out to be a loose fuel pump connector..
by
Add a comment
I would suspect fuel delivery system and the high voltage circuitry.
2 Comments:
It has all kinds of fuel pressure. and yhe high voltage circuitry? how might i check that?
by
Search this site: bobistheoilguy.com Look in the Automotive and Mechanical forums.
You will also need basic voltmeter and ohmmeter test equipment.
by
Add a comment
i have almost the same problem my dodge neon wont even turn over it doesnt even do a click what do i do ? can anhy body help me
Add a comment
Add your answer
Brandon B will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 22
All Time: 523
