Released in 2011 - Core i3-2330M processor
Half of the Screen Broken
I dropped the laptop on a carpeted floor. The screen itself did not crack or shatter, but now only the left hand side of the screen works. It is split right down the middle at the webcam. It still has color. It works fine when I hook it up to an external monitor, and other than that there is only a small crack on the cover-corner where it hit the ground. Any help would be greatly appreciated.
Add a comment
Chosen Solution
Ray, disassemble you laptop and take a look at the connectors. It is possible that you have a torn cable, broken connector or a broken CCFL. If any of that should not work, you may have to replace the LCD. You can get the service manual from here Hope this helps, good luck.
Score 1
Add a comment
Hi,
This might be a cable connecting your LCD with laptop board problem. I would recommend you to take it to a local technician and see if replacing that cable can resolve the issue otherwise you have to go for a new LCD.
Good Luck.
1 Comment:
Hi! I found this website because I have an issue with my dell laptop, half of the screen was not working, I brought it back from the technician because he cannot repair it, also he was trying to order a 40 pins LCD but he mentioned that there's no available, may i know if do you have any suggestions regarding on this because I don't have any idea about laptop issues. Thank you
by
Add a comment
Add your answer
Ray will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 20
All Time: 1,231
