Up to 20% off select tools
Pocket-sized GPS receiver with a 4.3" touchscreen and Bluetooth.
Back removal to replace battery
I would like to remove the back cover on my Go 720 but have had no luck to date. need help.
Score -1
Add a comment
Chosen Solution
ron, follow the instructions for a battery replacement, they will show you how to disassemble your Go720. Here is a video on it and here are the written instructions. Hope you will take lots of pictures and create a guide for this ;-) Good Luck.
Score 1
Add a comment
when trying to open a device first look for any visible screws, then check and see if screws are hidden (under stickers or rubber feet). to check under stickers without removing the sticker just run your finger or a tool over the sticker and see if you find a round dip where a screw will be.
last will be clips under a frame, use a pry tool to lift the edges till you hear the clips pop and release and work your way around. if you dont have a pry tool you can use a butter knife to a small chisel but i recommend something that hard plastic to not scratch or damage anything.
hope this was helpful, good luck and reply back with your results.
Add a comment
Add your answer
ron will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 1,403
