Repair guides, disassembly, and troubleshooting information for the second-generation Apple iPad with CDMA 3G cellular networking (Verizon), available with 16, 32, or 64 GB of storage. Features a dual core A5 processor. Released in March 2011. Identified by model number A1397. Repairs require the use of heat and careful prying.
power button will not put ipad to sleep
I've got an iPad that I'm fixing the screen on. I've got something bizarre going on that the power button won't put it in or take it out of sleep mode. However, it will power the iPad down. I'm pretty sure I didn't rip the power flex cable. Been down that road before. Any ideas?
Score 1
1 Comment
I was able to resolve the issue by turning off the setting for the smart cover. After that it worked like it should.
by
Add a comment
1 Answer
Chosen Solution
Try turning the Smart Cover settings off. If the issue disappeared, then the magnetic sensor is damaged. You can also try the compass, which should also be dead.
If the problem is not caused by the sensor, try restoring the device
Score 1
Add a comment
Add your answer
Ethan Grier will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 23
All Time: 2,395
