Entry level Photosmart printer introduced in 2009. Uses HP Tri-Color ink cartridges with a disposable printhead.
door open on display
printer door is closed but still get door open on display
Score -1
Add a comment
Chosen Solution
THIS forum post may assist you.
Score 2
Add a comment
If you open the cartridge door then you will find a button type switch associated with some liver bit going inside, you need to make it sure first that whether its broken or not if its broken then you can permanently press it by putting some tape on its top.
Add a comment
Add your answer
Dan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 22
All Time: 580
