Released 2006, identified by model number E1705
video card not working need help locating same
video card does not work, it is built into the motherboard, or is it? Mine does not have a big video card as displayed in your pictures. There is a small green card plugged into the motherboard where it would appear the one you removed in the pictures. Is this little green card the actual video card ?
I have taken pictures if that helps.
Score -1
Add a comment
1 Answer
Chosen Solution
Michael Crawford, that is a depends. "A removable (or discrete) video card is optional and present only if ordered by the customer. Standard video is integrated on the system board and is not customer removable." Download the service manual from here. It will help you to disassemble your computer, explain the parts to you, that way you will know what you have. you'll also find an excellent write-up on here. Hope this helps, good luck.
Score 1
Add a comment
Add your answer
Michael Crawford will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 14
All Time: 404
