Up to 20% off select tools
The HTC Desire HD is an Android smartphone by HTC Corporation.
Screen replacement help me
I have an htc desire hd phone with broken screen but the phone works smoothly and finely.
Should i have to replace the whole lcd screen or just the screen digitizer.
And if i have to replace only the screen digitizer , is it normal to replace the screen digitizer ande is it easy???
>>help<<
Score 1
Add a comment
Chosen Solution
Amit Pathak , yes it is possible, but it is anything but easy. Check this video and this one for more information. Some more instructions on here as well. You will need a heat source to remove the digitizer from the screen. Check on this question as well. Hope this helps, good luck.
Score 3
Add a comment
Thank you for that informations.
Add a comment
Add your answer
Amit Pathak will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 10
All Time: 1,907
