Repair guides, disassembly, and troubleshooting information for the second-generation Apple iPad with CDMA 3G cellular networking (Verizon), available with 16, 32, or 64 GB of storage. Features a dual core A5 processor. Released in March 2011. Identified by model number A1397. Repairs require the use of heat and careful prying.
Backlight but no display on LCD
I have an ipad 2 that may or may not have been dropped by a child the issue that I am having is that there is nothing being displayed on the ipad, but the backlight is coming on and the ipad is recognized by i tunes i will be disassembling tomorrow any tips if anyone has experienced this problem before would be great.
Score 2
1 Comment:
Hit the corner of the Ipad2 near the Headphone Jack, this trick worked for me and a few other people on the apple forum.
by
Add a comment
I would first check the LCD's connection to the logic board, and the cable's connection to the LCD. If the connections are good, then it's likely your LCD is bad. Be VERY careful when removing the digitizer. If it's not damaged, you don't want to break it when removing it to check the connection, or replace the LCD. Good luck!
Add a comment
There are 4 square like ic under the lcd connection
make sure you have all 4
Add a comment
Try hitting the top left-hand corner(headphone jack) a few times with your palm, it worked for me
Add a comment
Can’t believe that, in 2026, this works for me too.
Add a comment
Add your answer
Alec will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 34
All Time: 1,702
