The Sony Cybershot DSC-W55 was released in early in the year 2007. It is upgraded with a 7.2 megapixel camera compared to the previous model's 5.1 camera and has 56mb of internal memory.
Flash does not work!
Turned camera on and heard a loud pop. Removed and charged NP-BG1 battery. Reinstalled charged battery, but battery discharged rapidly. Bought new NP-FG1 battery, charged battery, installed battery and got "E91:01 error code with flash symbol flashing on LCD screen. Camera takes pictures, but flash does not flash. I suspect the capacitor blew when the loud pop was heard. Any suggestions?
Where can I buy a replacement capacitor without buying the entire flash unit?
THANKS in advance.
Add a comment
1 Answer
Chosen Solution
Dick, the error code that you are getting is related to an issue with the flash or light on your camera. There are a two things that may have made that noise, Either your flash bulb, or your flash capacitor. Follow [http://he error code that you are getting is related to an issue with the flash or light on your camera. It's usually just replacing the flash bulb on the camera,|this guide] to either replace the capacitor or the whole assembly. the part numbers are as follows:
1-479-663-31 FLASH UNIT
1-112-819-11 ELECT 97uF 315V Capacitor
you can get it from here
A-1231-877-A ST-133 BOARD, COMPLETE
Hope this helps, good luck.
Score 2
3 Comments:
THANKS "oldturkey03", I plan to disassemble the camera and investigate further this week. Dick
by
На плате st-133 посмотри контакты конденсатора и детали которая распаяна под лампой . Может и в самом конденсаторе дело ! Тратить надо ...
by
сперва саму батарею проверь . а потом дальше ...
by
Add a comment
Add your answer
Dickie will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 37
All Time: 2,281
