The Nexus One (also known as the HTC Passion and Android Dev Phone 3) is a smartphone from Google (manufactured by HTC) that runs the Android operating system.
How do I remove the engraving?
Does anyone have any idea how I can remove the engraving that Google puts on the phone?
Score 2
Add a comment
Chosen Solution
Some light sanding but I wouldn't advise it, it could be a pretty bad thing for the case, as well as could result in some ugly scratches.
Score 1
Add a comment
Most Helpful Answer
This 3M headlight restoration kit would do the trick. You can also use this to buff scratches from any plastic, including the iPhone's glossy rear panel.
Score 4
Add a comment
You can also use a bit of chocolate of all things. Cheap chocolate especially, due to it's highly crystalized structure, it abrasive. Using this method although time consuming, will eventually buff out engraving and bring a high gloss polish to the surface.
Add a comment
Add your answer
Chris will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 21
All Time: 6,884
