Repair information for the 6th generation iPod nano. Released in September of 2010. Model Number: A1366.
Please help me! WATER DAMAGE
I accidentally washed My iPod in the washing machine and it wouldn't turn on. I put it in a bag of rice for 24 hours but nothing happened. when I took it apart the lcd fell apart. Please tell my how to fix it
Score 2
Add a comment
1 Answer
Chosen Solution
chanan, It seems this happens a lot. Here is my answer to the same question from a different person "The first step you should do is to disassemble your iPod. Use this guide to help you out. After that clean the iPod thouroughly by following this general guide. You a high grade isopropyl alcohol. Once you are sure the logic board, connectors (do not forget the dock connector), and cables are clean replace the battery. You can get it at places like this. Once you have all this accomplished, reevaluate for any residual (if any ) damage. In your case, you may have to replace the LCD as well. Follow this guide for that. Remember that this model is a PITA to work on but not impossible to fix. Hope this helps, good Luck.
here and here and one more here
iPod Nano 6th Generation Front Panel Assembly Image
Guide
iPod Nano 6th Generation Front Panel Assembly Replacement
Difficulty:
Moderate
35 minutes - 1 hour
iPod Nano 6th Generation Logic Board Assembly Image
Guide
iPod Nano 6th Generation Logic Board Assembly Replacement
Difficulty:
Moderate
30 minutes - 1 hour
Score 3
Add a comment
Add your answer
chanan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 19
All Time: 9,630
