Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
forgot my passcode. how do I reste the passcode
my son set the passcode and forgot it.. how do i reset the passcode?
Score 33
Add a comment
Chosen Solution
haley, just hook it up to the computer that it was setup on and restore it. Or you can unlock it putting the device into DFU mode and then restore it with iTunes, BUT this will erase all data on your iPhone. Here is an excellent description how to place your iPhone and iPod in DFU mode. Hope this helps, good luck.
Score 5
1 Comment:
I need password& username
by
Add a comment
You can reflash the phone from DFU mode, but you will lose all your data. If you have a backup, you can restore it after recovery.
iPhone - 4 / 4S / 5 / 5S / 5c / 6 / 6S - How to flash in DFU mode
Score 3
Add a comment
sir if u remember your icloud id or password so press home button or power bottun in same time then your i phone will be switch off bt dont leave home button hold it then u see itune logo then connect your iphone with itune in pc and then your pc automatically detect problem now u have 2 option 1 restore and 2 close you must click on restore its take some time after few minutes your iphone will be reset
Score -1
1 Comment:
iCloud lock was not present on this device. Please complete accurate research before posting.
by
Add a comment
Add your answer
haley will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 22
All Time: 30,723
