A garage door opener is a motorized device that opens and closes garage doors and is controlled by switches on the garage wall.
Garage door closes after opening
Hello!
Recently my garage door started closing immediately after being opened via the remote or the button inside the garage. After several attempts to open it, it finally stops going down again, or if you push it upward when it's near the top, it seems to stop it.
Anyone know what would cause this, and if there's a simple fix, or do I need a new garage door opener? Getting my car in the garage is like playing a strange video game, and one of these days it's going to scrape my car! :-(
My garage door opener is a Sears 139 65 3000.
Thanks!
John
Score 2
4 Comments
It eventually stopped automatically closing on its own, but it would still be interesting to know what component, etc., is responsible for this behavior.
by
Don't you just hate problems that solve themselves?
by
I don't mind them, as long as they stay solved, and don't become intermittent (as they usually do)
by
I had same problems although i was told even by eco that they dont auto close they sent a pdf and it had instructions
Hold up button until horizontal line appears on screen then push up or down a number will appear 0 is deactivate 1 being shortest time up to ? Longest time press set to select
by
Add a comment
Chosen Solution
I wonder if it's "reversing" (Not closing on it's own) because it's binding or hitting an obsticle near the end of the upward portion of your track - check your supports, one may be lose or have dropped a bolt/nut that's in the track. If you have torsion springs the cable drum/pulley may bind at the end of upward travel.
There are "tensions" or adjustments that can change the amount of pressure before reversing starts.... that may have vibrated to a setting that's too quick to reverse.
Score 2
Add a comment
There is an 'open force' adjustment that can be changed. Sometimes it goes out of adjustment over time as the weight of the garage door can change with humidity or moisture and/or the springs change tension especially after being replaced. Or as machead3 states, through vibration from ther drive train.
The manual for this opener can be downloaded:
http://www.managemylife.com/mmh/pd_downl...
Reference page 13.
Score 1
Add a comment
I think it could be something in the eyes at the bottom of the door not lined up.
Add a comment
I had same problem and although told they dont auto cose i have found setting for eco .
Press and hold up untill horizontal line appears on screen then push up or down a number will appear 1 is shortest time higher longer 0 is auto close off
Add a comment
Add your answer
rdklinc will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 31
All Time: 8,892
