Netbook released 2011. Powered by Windows 7 Starter. Identified by model number 1018P-PU17-BK.
DC power jack pin repair
The power pin on the DC jack has been loose and will not charge my battery. Is there a way to fix the pin so that the plug will transfer current, without getting a replacement?
Score -1
Add a comment
1 Answer
Rishi, the only way you can fix it properly is by replacing the jack. You do want to make sure that it is still properly soldered onto the mother board. If it is loose, you may solder it back on, if it is the jack itself, you will have to replace it.
Add a comment
Add your answer
Rishi will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 26
All Time: 1,758
