The APC RS 1000 is an uninterruptible power supply capable of delivering 600 Watts.
Overload alarm lights and sound
My ups, after 5 years of continuous operation shows the overload's light .
I unplugged the PC and I replaced the battery but I have not solved the problem.
Then I opened it to see if there are components that are burned or leak but nothing.
To be sure I replaced the cooling fan but nothing has changed.
Can anyone give me some tips?
Thank you very much.
Score 5
1 Comment
Hi, i had the same problem twice...!!!
My battery was ok, everything was ok but
the beep keep going on, for overload...
Both times i fixed doing these steps...
- Turn off the unit
- Flip over the unit
- Open the battery-cap and turn the power on
- Green Light is flashing
- Try Now (with the green light flashing) to disconnect the battery...
- Now it should be ON with the Empty battery light on (Red light)
- Connect again the battery as it is...
Now it should be ok...!!!
Good Luck...
by
Add a comment
Chosen Solution
Thanks to all. I have not solved the problem. I replaced the old ups with a new one.
Score 2
Add a comment
Most Helpful Answer
Roberto, If it alarms, even with nothing plugged in, then it is possible that one of the MOSFET on your mainboard has failed.
Score 4
3 Comments:
metal–oxide–semiconductor field-effect transistor (MOSFET)
http://en.wikipedia.org/wiki/MOSFET
by
Did you solve the problem? Same problem here, 4 years later..
daigoph@gmail.com
by
Green light not so always yellow light and 5 Second deep alarm
by
Add a comment
- Turn off the unit
Good Luck...
Score 2
1 Comment:
Thank you but I replaced the old ups with a new one. Yours sincerely.
by
Add a comment
I too facing the same problem....battery charging process is fine...but when i turn on the inverter it trips and shows overload and keep continuosly beep beeps....pls help me to solve this problem....i expecting board level service suggestions ...thank you
Score 1
Add a comment
My problem solved with removing the all cables also power cable wait 5 minute & connect cable again it's working.
Add a comment
Add your answer
Roberto will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 93
All Time: 39,278
