Quartz Extreme not longer supported?
Two days ago Top Sites disappeared from Safari, than I see that iWeb dis not show pages, iPhoto did not work well, iTunes did not show cover flow and finally Google Earth didi not show anything. I discover that in Info on my Mac, on Monitor information Quartz Extreme is not supported!
Fiollowing the description...
ATI Radeon X600 Pro:
Modello Chipset: ATY,RV370
Tipo: Monitor
Bus: PCI
Slot: PCI-E
VRAM (totale): 128 MB
Fornitore: ATI (0x1002)
ID dispositivo: 0x5b62
ID revisione: 0x0000
Revisione ROM: 113-xxxxx-113
Monitor:
iMac:
Tipo di monitor: LCD
Risoluzione: 1440 x 900
Profondità: Colore 32-bit
Integrato: Sì
Core Image: Non Supportato
Monitor principale: Sì
Mirror: Spento
Online: Sì
Quartz Extreme: Non Supportato
Monitor:
Stato: Nessun monitor collegato
Has anyone idea about what's happening? I can't use my Mac in this state...
Thank you very much for any help and suggesty.
Gaetano Zagra - Italy
Score 1
Add a comment
Chosen Solution
Thank you very much for all the support. I have finally solved reinstalling MacOSX from a Combo Update. I think ity was a corrupted driver. Now this is my system configuration (as was time ago)
Tipo: Monitor
Bus: PCI
Slot: PCI-E
Monitor:
iMac:
Integrato: Sì
Core Image: Supportato
Mirror: Spento
Online: Sì
Quartz Extreme: Supportato
Monitor:
Thank you again
Score 1
Add a comment
Most Helpful Answer
Quartz Extreme should always work on that mac. Try resetting the PRAM, and the PMU.
Score 1
3 Comments:
hank you very much for the suggest. I reset PRAM and PMU (unplug all cable, wait and re-plug cable while pressing ON button, release and start again).
Sadly nothing has changed.
I also reset NVRAM (Command+Option+O+F at startup, then reset-nvram, set-defaults, reset-all), but nothing.
I have heard of a phantomatic SMU or PMU button reset on the logic board... any suggest for it?
Thank you again for the help.
by
I'm not entirely sure where it is, if it exists, but i will check for you and see if I find anything.
by
Resetting the SMU button is in one of the last steps in this guide: http://support.apple.com/kb/TS2094
by
Add a comment
Both my mac-minis developed the "Quartz Extreme not longer supported" problem. I started my project on one then switched to the other. Reinstalling the system fixed this problem for me. It's a tedious fix but I was on a deadline and none of the other "fixes" were working for me (like changing the display settings or restarting) Plus I ran out of computers to switch to. I was surprised that this problem goes back to early 2008 and Apple has yet to address it in any serious way. I did an exhaustive search and finally came across the re-install fix here. Thanks ifixit.com!
Add a comment
re-Install or upgrade mac os x to version 10.5 and upgrade safari 5.0.6 and itune 10.5 then you can see Quartz Extreme: Supportato ok
Add a comment
The remedy is to reinstall over the existing os, then the quartz comes back.
I see the quartz disappeared under 2 conditions so far,
1. os crash, reboot, no more quartz
2. when the space filling up, apps start to freeze, I close all the apps, then restart, then quartz has gone
Mine is mac air, so the space is pretty thin, pry why it happens to me so many times.
I think it has to do with the corruption of some config files, Apple should find the way to bombproof them.
Add a comment
Add your answer
Gaetano Zagra will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 20
All Time: 2,446
