<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;MacBook Air 11&quot; Mid 2012&quot;]]></title>
<link>https://www.ifixit.com/Answers/Device/MacBook_Air_11%22_Mid_2012/All?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;MacBook Air 11&quot; Mid 2012&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Fri, 29 May 2026 11:57:01 -0700</pubDate>
<item>
<title><![CDATA[MacBook Air 11" Mid 2012: 3x 64 GB SSD - Q Folder @ Boot]]></title>
<description><![CDATA[<p>2012 MBA A1465 11&quot; - Tested with 3x SSD's &amp; all I get is a Q folder at boot. I know these SSD's do fail as they are so small in capacity, but one of them I was previously able to clean install OS Catalina on using another unit and that one aaso displays the Q folder on this unit that arrived for this same issue. <a class="user-mention-link notranslate" href="/User/263105/oldturkey03">@oldturkey03</a> Could this be a board issue and if so where to check as I currently don't have another working 2012 to test these SSD's on as they are the 7/17 pin layout unique to this series of Macbook.</p>
<p>I asked Chat GPT:</p>
<ul><li>SSD power rail missing or unstable</li><li>Corrosion/liquid damage around SSD connector</li><li>Broken SSD PCIe data lines</li><li>Clock/reset signal issue</li><li>PCH communication fault</li><li>SMC-related power gating issue</li></ul>
<p>The “33 KB device” symptom usually means Recovery only sees its own RAM disk or recovery environment, not the actual internal SSD</p>
<ol><li>Measure SSD power rails<br />You should verify:</li><li>PP3V3_SSD</li><li>SSD enable signals</li><li>PCIe reset</li></ol>
<p>⟐ Edited by author May 25, 2026 at 2:48 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/955923/3x+64+GB+SSD+-+Q+Folder+@+Boot</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/955923</guid>
<pubDate>Mon, 25 May 2026 02:48:36 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Air 11" Mid 2012: Stock SSD "Uninitialized' / Missing in Disk Utility]]></title>
<description><![CDATA[<p>How do I get this internal SSD back to normality or is it done?</p>
<p>33kb Volume only is displayed. Unable to partition or erase.</p>
<p>Attempting to install Catalina on a unit that previously had Catalina installed.</p>
<p>Ignore the other drive that is highlighted as that is my external multi installer drive.</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/HpCS5JivS6sFDqEl.standard" width="282" height="213" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/HpCS5JivS6sFDqEl.huge&quot;, '', 'width=1583,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/gFDsqKRA6GeruPdL.standard" width="282" height="175" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/gFDsqKRA6GeruPdL.huge&quot;, '', 'width=1600,height=997')" /></div>
<p>It is the same thing with another SSD except the other drive isn't listed at all, just the base system. Failed drives?</p>
<p>Windows was never installed on either of these drives, this has been confirmed by previous owners.</p>
<p>This is relevant to my other post  <a href="/Answers/View/955923/3x+64+GB+SSD+-+Q+Folder+@+Boot">3x 64 GB SSD - Q Folder @ Boot</a></p>
<p>UPDATE: Tried with a Windows installer.</p>
<p>SSD (1) Gave me this:</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/pU31JEbuZdAlwHAA.standard" width="282" height="165" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/pU31JEbuZdAlwHAA.huge&quot;, '', 'width=1600,height=939')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/cKILGcZG2euUJbdp.standard" width="282" height="200" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/cKILGcZG2euUJbdp.huge&quot;, '', 'width=1600,height=1132')" /></div>
<p>SSD (2) Gave me this:</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/LNfEY6obuoAgUdW4.standard" width="282" height="158" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/LNfEY6obuoAgUdW4.huge&quot;, '', 'width=1600,height=902')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/gItdpwUtnieVujUk.standard" width="282" height="158" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/gItdpwUtnieVujUk.huge&quot;, '', 'width=1600,height=902')" /></div>
<p>After hitting OK it rebooted to the Q folder.</p>
<p>Chap GPT suggests the following.</p>
<ol><li value="2">Measure SSD power rails<br />You should verify:</li><li>PP3V3_SSD</li><li>SSD enable signals</li><li>PCIe reset</li></ol>
<p>⟐ Edited by author May 25, 2026 at 2:46 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/956083/Stock+SSD+%22Uninitialized&#039;+-+Missing+in+Disk+Utility</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/956083</guid>
<pubDate>Mon, 25 May 2026 02:46:06 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Air 11" Mid 2012: I need to install an OS but I wiped the drive]]></title>
<description><![CDATA[<p>Hi so I was trying to install Windows on my Mac and halfway through the mac just shuts off as I was installing Windows to use this as a main laptop for some time I was using the whole hard drive and I never created a drive I could boot the old os x off of</p>
<p>I have tried external windows 10 and ubuntu drives but I can not get an os to boot also the screen is just completely black upon opening the lid and powering on along with the keyboard backlight does not turn on and the apple logo on the back does not light up but when I plug some thing in to the usb ports I can see light on the device I plugged in showing drive activity and if I press caps lock on the internal keyboard the caps lock light will come on</p>
<p>-Zach Ross</p>
<p>⟐ Commented April 29, 2025 at 9:41 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/561127/I+need+to+install+an+OS+but+I+wiped+the+drive</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/561127</guid>
<pubDate>Tue, 29 Apr 2025 09:41:07 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Air 11" Mid 2012: My speakers stopped working after spilling coffee on my laptop.]]></title>
<description><![CDATA[<p>I spilled coffee on my macbook air's keyboard and speaker. I immediately turned the laptop off and dried the keyboard and left the laptop in a bag of rice for 24 hours. Now the laptop works well, keyboard is good. But the speakers don't work. But when headphones plugged in the sound works greatly.</p>
<p>Help please!</p>
<p>⟐ Commented January 17, 2025 at 2:24 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/146526/My+speakers+stopped+working+after+spilling+coffee+on+my+laptop.</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/146526</guid>
<pubDate>Fri, 17 Jan 2025 02:24:24 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Air 11" Mid 2012: MBA 2012 Logic board in MBA 2011 case]]></title>
<description><![CDATA[<p>Hi,</p>
<p>I want to upgrade my MacBook Air 11’ 2011 with the new MacBook Air 11’ 2012 logic board because I found a friend who want to sell me this very very cheap.</p>
<p>Is it possible to buy logic board + io board + wifi card + SSD from MBA 11’ 2012 and put it into MacBook Air 11’ 2011?</p>
<p>Looks like it will be an easy switch because display battery and keyboard are fully compatible. For SSD I will just change the cheap adapter from my old MBA 2011 M.2 SSD.</p>
<p>⟐ Answered May 29, 2024 at 16:05 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/579429/MBA+2012+Logic+board+in+MBA+2011+case</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/579429</guid>
<pubDate>Wed, 29 May 2024 16:05:53 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Air 11" Mid 2012: The Dreadded White Screen @ Boot]]></title>
<description><![CDATA[<p>Hi, So I have a MBA 2012 A1465 that suddenly ONLY boots to a white screen.</p>
<p>I have tired these steps:</p>
<p>1 - Disconnected Battery and reset SMC</p>
<p>2 - Reset NV/PRAM - SHFT or CMD+OPT+P+R - Nothing Happens screen stays white</p>
<p>Laptop does not restart or lights on the charger do not change colors.</p>
<p>3 - Recovery Mode CMD+R - Nothing Happens screen stays white</p>
<p>4 - Verbose Mode CMD+V - Nothing Happens GREY screen.</p>
<p>5 - Shift Key boot to Safe Mode - Nothing Happens screen stays white</p>
<p>6 - &quot;D' Apple diagnostics - Nothing happens screen stays white</p>
<p>7 - Swapping out the SSD  with a known working SSD with the same OS (Catalina) - Nothing Happens still white. (The original SSD is working fine on another machine)</p>
<p>8 - Reconnecting &amp; cleaning the screen &amp; keyboard connector</p>
<p>9 - Cleaning everything inside the said unit / reconnecting all cables etc /</p>
<p>10 - Trying another screen - Nothing Happens still white</p>
<p>11 - Changing batteries - Nothing Happens still white</p>
<p>12- Booting with no keyboard connected - Nothing screen stays white</p>
<p>When the unit is powered off and I connect the charger it powers up by itself.</p>
<p>Connected to an external display at boot has no effect (No signal) odd/</p>
<p>I guess it is once again a logic board issue somewhere along the line.....</p>
<p>The only thing left to do that I can think of is to put the logic board into another same year model using that models components.... maybe it could it be a problem with the keyboard though it seems to be fine? There was never any water damage, internally looked clean, Asking you guys if you can shine some light on what maybe is an easy solution or am I once again to fear the worst.</p>
<ul><li>Command (⌘)-R Install the latest macOS that was installed on your Mac.</li><li>Option-⌘-R Upgrade to the latest macOS compatible with your Mac.</li><li>Shift-Option-⌘-R Install the macOS that came with your Mac, or the closest version still available. (I get a grey screen with a line down the middle)/</li></ul>
<p>*</p>
<p>Image of the internals of the 2012 below - Cheers in advance!</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/iOPpNl3bAEsTAtI2.standard" width="282" height="158" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/iOPpNl3bAEsTAtI2.huge&quot;, '', 'width=1600,height=902')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/DBXtwJUYQgvt1ciq.standard" width="282" height="158" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/DBXtwJUYQgvt1ciq.huge&quot;, '', 'width=1600,height=902')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/MVBs6rDawrFQTPhI.standard" width="282" height="158" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/MVBs6rDawrFQTPhI.huge&quot;, '', 'width=1600,height=902')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/QfQiDbmO2LL1LrWq.standard" width="282" height="100" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/QfQiDbmO2LL1LrWq.huge&quot;, '', 'width=1600,height=567')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/pQXCCXMRYsLsGMlP.standard" width="262" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/pQXCCXMRYsLsGMlP.huge&quot;, '', 'width=1396,height=1200')" /></div>
<p>⟐ Commented May 24, 2024 at 4:54 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/849057/The+Dreadded+White+Screen+@+Boot</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/849057</guid>
<pubDate>Fri, 24 May 2024 04:54:40 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Air 11" Mid 2012: Screen replacment Model A1370]]></title>
<description><![CDATA[<p>Will a macbook air 11 inch model A1465 screen fit on a macbook air 11 inch model A1370?</p>
<p>⟐ Commented April 25, 2024 at 21:57 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/466483/Screen+replacment+Model+A1370</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/466483</guid>
<pubDate>Thu, 25 Apr 2024 21:57:30 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Air 11" Mid 2012: Backlight Not Working...Should I replace Display or Fuse?]]></title>
<description><![CDATA[<p>My brother has a Mid-2012 Macbook Air 11&quot;.  He was recently on a flight and was trying to place his bag (which held the Macbook Air) into the cabin compartment.  Unfortunately, he lost his grip and the bag feel onto the ground.</p>
<p>A couple of hours later when he went to turn the Macbook and that's where he first noticed the problem with the backlight.  He says that when he first turned it on, the screen was very dim, but he was able to make out a dialog box on MacOS.  Then he said it flickered and went completely dim.</p>
<p>When he gave it to me, the screen was completely dark.  However, by shinning a light through the Apple logo, I was able to see the MacOS desktop and confirm it was the backlight that was not-functioning and not the LCD.   I connected his laptop to an external monitor and was able to confirm that everything else was working fine.</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/JCUmSDJ2TuEGkkCV.standard" width="282" height="211" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/JCUmSDJ2TuEGkkCV.huge&quot;, '', 'width=1600,height=1200')" /></div>
<p>At that point, my initial instinct was to just replace the display.  I found a couple of eBay listings of Macbook Air displays that came with the full display housing.  However, in the course of my research, I've read a lot of support threads identifying the Fuse on the mainboard of the Mac as the reason why backlights on the MBA might fail.</p>
<p>Here's a picture of the (what I think is the) fuse on the mainboard:</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/wUFQtJWMHgJQHaRW.standard" width="282" height="187" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/wUFQtJWMHgJQHaRW.huge&quot;, '', 'width=1600,height=1060')" /></div>
<p><strong>My Question:</strong>  How do I know which is the right solution? How do I know if the Fuse is blown or not?  Will buying the display off eBay solve the problem regardless?  Or will I end up wasting money if it turns out to be a problem with the Fuse?</p>
<p>⟐ Answered March 15, 2024 at 16:47 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/387544/Backlight+Not+Working...Should+I+replace+Display+or+Fuse</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/387544</guid>
<pubDate>Fri, 15 Mar 2024 16:47:30 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Air 11" Mid 2012: Black screen background, cursor visible and movable, NOTHING WORKS.]]></title>
<description><![CDATA[<p>I am working on my dad's old MacBook Air (A1465). None of us knew the password, so I used the guest user account. Everything worked fine until I logged out. Now I have this black screen with the cursor. I can move the cursor; I can even do the thing where if I move it around quickly, it gets bigger, but that's it. If any of the qwerty (nonfunction/command) keys are pressed, a quiet clicking sound can barely be heard from the laptop.</p>
<p>I powered it on using an off-brand charger for the first time since about 2017. My dad hasn't used it in years and passed it to my little brother, who certainly did not take good care of it—like everything he owns—and when my family moved to Orlando recently, they dug it out and gave it to me. My goal was to take my dad's old data off of it, wipe it, and put Xubuntu on it.</p>
<p>I have tried every command, trick, and tip I knew or could find online. I have never seen this before, and there is ZERO information anywhere on what this is, what causes it, and how to fix it. I only found ONE comment that sounded close enough on this forum from 2014 that went unanswered. I am at a complete loss.</p>
<p>Before anyone says anything, I have already tried draining the battery. When plugged back in, it skips the reboot altogether and goes right back to this. The power button does not work. Aside from making that faint clicking sound I mentioned earlier, none of the keys work. All I have is the touchpad. It has stayed consistently warm since doing this. The cursor movement is smooth and responsive. At one point, after randomly mashing buttons in frustration, it changed from the pointer to a text cursor (the &quot;I&quot; looking one), but after a second, it went back. It's trying to do something, and it's stuck, I am at a complete loss here.</p>
<p>Specs:</p>
<p>MacOS 10.13 (all I remember seeing)</p>
<p>2 Core i7</p>
<p>8GB DDR3 RAM</p>
<p>128GB SSD (Almost full; only 5.8GB remaining)</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/IfRnJbrfwD5pwIvL.standard" width="169" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/IfRnJbrfwD5pwIvL.huge&quot;, '', 'width=900,height=1200')" /></div>
<p>⟐ Answered February 27, 2024 at 4:26 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/838663/Black+screen+background,+cursor+visible+and+movable,+NOTHING+WORKS.</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/838663</guid>
<pubDate>Tue, 27 Feb 2024 04:26:59 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Air 11" Mid 2012: Screen Hinges Worn Out]]></title>
<description><![CDATA[<p>My screen hinges have 'worn out' (the display does not hold its 'working' position). Can I replace the hinges, or one of them, or somehow differently repair this, maybe tighten the hinges?</p>
<p>⟐ Answered June 24, 2023 at 19:40 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/798482/Screen+Hinges+Worn+Out</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/798482</guid>
<pubDate>Sat, 24 Jun 2023 19:40:17 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Air 11" Mid 2012: Need help differentiating I7 from i5 logic board]]></title>
<description><![CDATA[<p>I am replacing an i5 logic board on a an 11&quot; 2012 MacBook Air with an i7 logic board of the same era. I mistakenly but both boards next to one another and now I can't remember which is which. Is there a way to tell? All help is appreciated!! Thanks.</p>
<p>⟐ Answered June 13, 2023 at 20:02 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/796827/Need+help+differentiating+I7+from+i5+logic+board</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/796827</guid>
<pubDate>Tue, 13 Jun 2023 20:02:06 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Air 11" Mid 2012: MacBook won’t start]]></title>
<description><![CDATA[<p>Yes I spilled a beer on my MacBook Air. I immediately did everything I could to get the beer out. After letting it sit for several days I tore it down to the upper case to see the damage. There was no trace of beer anywhere. I looked for any visible corrosion but couldn’t find any as well.</p>
<p>My question is when I hook the battery up or plug it in the fan will start, the chime chimes and the screen lights up but only for a few seconds then shuts off. It won’t power up otherwise, I tried hooking up the battery without the keypad or trackpad plugged in and the fan didn’t even turn on.</p>
<p>So I just wonder what component I need to replace in order to get my Mac working again.</p>
<p>⟐ Commented April 21, 2023 at 3:30 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/782955/MacBook+won%E2%80%99t+start</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/782955</guid>
<pubDate>Fri, 21 Apr 2023 03:30:53 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Air 11" Mid 2012: MacBook Air 2012 - WiFi not detected!]]></title>
<description><![CDATA[<p>Hi!<br />I have a really nasty and dusty Macbook Air mid 2012, which couldn't turn on. After a dust-off and cleaning it turned on again. I think the charging port was making a bad connection. I have cleaned the logic board too with IPA and a light brush.<br />I have Bluetooth, but not WiFi. The WiFi card is getting a little bit warm, but nothing crazy.</p>
<p>How can I figure out what the problem is? Any known voltages out there or something like that? Can the U1800 (pch) chip have anything to do with this? Could the Airport card be half-bad?</p>
<p>Thank you in advance!</p>
<p>⟐ Commented April 13, 2023 at 11:41 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/779972/MacBook+Air+2012+-+WiFi+not+detected!</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/779972</guid>
<pubDate>Thu, 13 Apr 2023 11:41:50 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Air 11" Mid 2012: erased my Mac took to Staples]]></title>
<description><![CDATA[<p>I erased my macbook air and dropped off at Staples for recycle. A week later I received a email message from “Find My” . My Macbook Air was found at a location 13 miles from my home . This location is nowhere near Staples. Should I be concerned unit was not completely erased?</p>
<p>⟐ Answered January 26, 2023 at 8:38 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/766210/erased+my+Mac+took+to+Staples</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/766210</guid>
<pubDate>Thu, 26 Jan 2023 08:38:21 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Air 11" Mid 2012: Sudden screen glitches & freezes, requiring force restart]]></title>
<description><![CDATA[<p>Hello!</p>
<p>My 2012 MacBook Air (I have the 2.0 GHz dual i7 + 8 GB of RAM model) has, for the last few months, started crashing at random, requiring a force restart.</p>
<p>Out of nowhere, the screen gets glitchy ~ you can see what was there, but its colors &amp; shapes distort. If any audio was playing, it also becomes just a glitchy (loud!) mess. The only solution is to hold down the power switch for 10 seconds and force a restart. Or sometimes it restarts on its own after a few seconds.</p>
<p>The troubleshooting I’ve done:</p>
<p>1) installed a clean OS (Mojave) on a separate partition. Still happens.</p>
<p>2) happens on both battery &amp; two different AC power adapters.</p>
<p>3) happens with &amp; without external peripherals connected (powered USB3 hub, audio interface connected via firewire-thunderbold adapter).</p>
<p>4) I’ve reset PRAM &amp; SMC. No help.</p>
<p>5) happens under heavy &amp; light workloads, even sometimes sitting idle (i’ll return to my desk to find it has restarted itself).</p>
<p>6) sprayed compressed air inside all vents in case something was blocked by dust causing overheating. No help.</p>
<p>7) Ran Repair Disk in Disk Utility after starting up from recovery partition. No results.</p>
<p>What I haven’t done: replace the battery, which reports “Replace Soon”.  I don’t want to throw big money at the machine if its logic board is about to die.</p>
<p>Any thoughts? The machine (aside from random crashes) still suits my needs perfectly, and I’d really like to not have to replace it.</p>
<p>Thanks in advance!</p>
<p>~ Peter in Athens</p>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Update" class="header">Update</h3></div>
<p>Adding screenshots of CoconutBattery, per request!</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/DDUXWWMMjcVCCGJY.standard" width="239" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/DDUXWWMMjcVCCGJY.full&quot;, '', 'width=637,height=602')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/JLoqXQVEMYe6naGL.standard" width="188" height="225" class="hasMenu hasLarge" alt="Block Image" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/JLoqXQVEMYe6naGL.full&quot;, '', 'width=503,height=602')" /></div>
<p>⟐ Commented October 02, 2022 at 7:37 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/546529/Sudden+screen+glitches+&amp;+freezes,+requiring+force+restart</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/546529</guid>
<pubDate>Sun, 02 Oct 2022 07:37:31 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Air 11" Mid 2012: Trackpad not working: swollen battery or bad trackpad?]]></title>
<description><![CDATA[<p>Hi All,</p>
<p>The Trackpad on my mid-2012 11&quot; MacBook Air stopped working. The battery doesn't seem to be losing power. Other than opening up the computer and looking for swelling in the battery is there any easy way to diagnose the cause (i.e., is it a bad trackpad or a bad battery?). I'm hoping to order the right part (trackpad or new battery) before I open the computer up.</p>
<p>⟐ Commented May 09, 2022 at 5:05 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/318828/Trackpad+not+working:+swollen+battery+or+bad+trackpad</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/318828</guid>
<pubDate>Mon, 09 May 2022 05:05:13 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Air 11" Mid 2012: Will I be able to set up Win10 bootcamp with a 3rd party ssd/adapter?]]></title>
<description><![CDATA[<p>I recently started using  my macbook air 2012 11” as my main pc.</p>
<p>Catalina 10.15.6, 64gb apfs oem ssd.</p>
<p>I don’t have enough money to buy something better, it’s running fine but I decided to upgrade the ssd with this adapter:</p>
<p><a href="https://www.amazon.ca/gp/product/B07NSFY5XM/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&amp;psc=1" rel="nofollow noopener noreferrer" title="https://www.amazon.ca/gp/product/B07NSFY5XM/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&amp;amp;psc=1">https://www.amazon.ca/gp/product/B07NSFY...</a></p>
<p>and this 1tb internal ssd:</p>
<p><a href="https://www.amazon.ca/gp/product/B073SB2MXT/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&amp;psc=1" rel="nofollow noopener noreferrer" title="https://www.amazon.ca/gp/product/B073SB2MXT/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&amp;amp;psc=1">https://www.amazon.ca/gp/product/B073SB2...</a></p>
<p>m2 2280</p>
<p>Comments on amazon seem to indicate that this combo works fine for MacOS, and it’s a lot cheaper than OWC/transcend,  I know it might not be as compatible but I can’t afford those and it’s not worth it to me to put much money into a laptop this old that big sur will drop soon.</p>
<p>Anyway, I would like to use some of the space for Windows, I thought it would be easy but after ordering I found out there might be problems,</p>
<p>I’ve been told the 4gb ram will make VM not a pleasant experience so that’s out, I would like to run boot camp, but I’ve read and recieved conflicting opinions about whether boot camp will play nice with third party ssds.</p>
<p>One person said it should be ok, another person with much more experience in the matter told me that there will be issues, “macOS works on third-party SSDs, but the Apple SSD drivers used to install Windows will not.”</p>
<p>I just wanted a second opinion of is it worth trying bootcamp with this specific setup and if there are any work arounds I could try if not? Googling people’s problem threads is not very useful because every macbook/MacOs/ssd is different and posts from a few years ago may not be applicable to my computer. thanks.</p>
<p>⟐ Commented March 02, 2022 at 15:02 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/652493/Will+I+be+able+to+set+up+Win10+bootcamp+with+a+3rd+party+ssd-adapter</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/652493</guid>
<pubDate>Wed, 02 Mar 2022 15:02:27 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Air 11" Mid 2012: MacBook Air not charging, turns on, no LED]]></title>
<description><![CDATA[<p>I am using a third party power adapter I bought off of ebay to charge my Macbook Air. The LED will not turn on and the battery will not charge, however the Macbook otherwise functions as normal.</p>
<p>I have tried everything under the sun to get it to charge again. I have reseated the battery, SMC reset, warmed the charger, and ran Apple diagnostics with no faults.</p>
<p>I strongly suspect it is the charger and I'm anxiously waiting for a friend to get back from vacation to lend me his.</p>
<p>A bit of history, before the this happened, my original Apple official charger had a stress break at the T-connector. As a result, I don't believe the grounding wires were making contact. I suspect this could have damaged something.</p>
<p>Here's my current Power readout. If anyone has this happen to them, I want to know what I have to replace before I go out and buy a new battery, charger, etc. If it is the logic board I am tempted just to sell it AS-IS.</p>
<p>Battery Information:</p>
<p>Model Information:</p>
<p>Serial Number:    [removed]</p>
<p>Manufacturer:    SMP</p>
<p>Device Name:    bq20z451</p>
<p>Pack Lot Code:    0</p>
<p>PCB Lot Code:    0</p>
<p>Firmware Version:    406</p>
<p>Hardware Revision:    000a</p>
<p>Cell Revision:    175</p>
<p>Charge Information:</p>
<p>Charge Remaining (mAh):    0</p>
<p>Fully Charged:    No</p>
<p>Charging:    No</p>
<p>Full Charge Capacity (mAh):    4079</p>
<p>Health Information:</p>
<p>Cycle Count:    542</p>
<p>Condition:    Normal</p>
<p>Battery Installed:    Yes</p>
<p>Amperage (mA):    0</p>
<p>Voltage (mV):    5894</p>
<p>System Power Settings:</p>
<p>AC Power:</p>
<p>System Sleep Timer (Minutes):    10</p>
<p>Disk Sleep Timer (Minutes):    10</p>
<p>Display Sleep Timer (Minutes):    10</p>
<p>Wake on AC Change:    No</p>
<p>Wake on Clamshell Open:    Yes</p>
<p>Wake on LAN:    Yes</p>
<p>AutoPowerOff Delay:    14400</p>
<p>AutoPowerOff Enabled:    1</p>
<p>Current Power Source:    Yes</p>
<p>DarkWakeBackgroundTasks:    1</p>
<p>Display Sleep Uses Dim:    Yes</p>
<p>PrioritizeNetworkReachabilityOverSleep:    0</p>
<p>Standby Delay:    4200</p>
<p>Standby Enabled:    1</p>
<p>Battery Power:</p>
<p>Display Sleep Timer (Minutes):    2</p>
<p>DarkWakeBackgroundTasks:    0</p>
<p>Reduce Brightness:    Yes</p>
<p>Hardware Configuration:</p>
<p>UPS Installed:    No</p>
<p>'''AC Charger Information:</p>
<p>Connected:    Yes</p>
<p>ID:    0x0000</p>
<p>Revision:    0x0000</p>
<p>Family:    0x0000</p>
<p>Serial Number:    0x00000000</p>
<p>Charging:    No'''</p>
<p>⟐ Commented January 28, 2022 at 22:01 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/205100/MacBook+Air+not+charging,+turns+on,+no+LED</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/205100</guid>
<pubDate>Fri, 28 Jan 2022 22:01:01 -0700</pubDate>
</item>
<item>
<title><![CDATA[MacBook Air 11" Mid 2012: MacBook only charges when fully drained]]></title>
<description><![CDATA[<p>I know this is old but we are having the same problem. I just wanted anyone else to know that this is not only a damage issue. We haven’t done anything to ours. It will only charge when completely dead. 2015 Macbook Air.</p>
<p>⟐ Commented January 01, 2022 at 11:39 MST</p>]]></description>
<link>https://www.ifixit.com/Answers/View/716911/MacBook+only+charges+when+fully+drained</link>
<guid isPermaLink="false" >https://www.ifixit.com/Answers/View/716911</guid>
<pubDate>Sat, 01 Jan 2022 11:39:58 -0700</pubDate>
</item>
</channel>
</rss>
