Student In Progress
This wiki is being worked on by hardworking students.
Anbernic RG28XX Screen Bleeding
Screen image is blurred and color has a bleeding effect around the edges. Follow these steps for correction.
Heat Expansion
The device might be too hot. The battery and heavy process load are often the culprits. Excessive heat can cause expansion of the hardware material and/or electronic issues. There is a simple solution to thermal management that doesn't require any tools.
- Power off the device while charging
- Avoid fast chargers - A standard or lower wattage charger brick (5V/1.5A or 5V/2A)
- Lower screen brightness when in use - Try to keep it at or under 50%
Back Shell Pressure
There can be quite a few mechanical issues that can fix the screen bleeding. It starts with taking a TR6 hex bit or Allan key that fits the four screws in the back. To correct this problem:
- Relieve Back Shell Pressure - Gently unscrew the rear four screws ¼ to a ½ turn each. The back shell of the device can cause screen bleeding by putting too much pressure on the screen. If it is screwed in too tightly it presses the edges of the screen into the casing, causing the screen bleed issue. This mechanical correction relieves pressure at pinch points around the screen.
- Gently Massage Display Panel - Use a microfiber cloth to lightly rub or massage the edge of the screen in small circular motions, using minimal force to avoid cracking the screen. This can relieve the pressure on the edges of the screen or unwedge the edges of the screen and casing where it sits uneven around the display.
Screen Replacement
The only solution for a cracked screen in a full DIY replacement. Do not worry, the steps are easy, will not take more than twenty minutes to do, and it is a very cost effective being around $30 at most. Before steps, make sure device is all the way powered off.
1) Display panel can be found on online platforms such as Amazon, Anbernic Parts Store, or AliExpress.
2) Take out the four back screws using a TR6 hex bit or Allan key and carefully remove the back shell.
3) Remove the battery and motherboard. Use a J000 screw to remove the motherboard, gently unplug the battery connection to the motherboard, and finally remove the screen ribbon cable connection by lifting the black panel on top of motherboard connector.
4) Using a heat gun or a blow dryer, anything with low-to-medium heat, to remove the adhesive beneath the glass.
5) Carefully press the screen out from the inside using a thin plastic prying tool to pull screen panel out of the frame. Clean off the adhesive with isopropyl alcohol.
6) Slide the new screen into the screen slot. Apply double-sided electronic tape to the frame and press the screen firmly in place.
7) Finally, reassemble the system. Reconnect all of the parts and put back the screws, reverse the order of steps.
0 Comments
