Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Device Needs Cleaned
Your device cleaning light turns on
Cleaning Light is On
Put cleaning solution into reservoir and press the cleaning button.
If additional help is needed visit:Cleaning Instructions
Device is Leaking
Your reservoir leaks or does not flow to brew basket after filling
Malfunctioning Reservoir
If water is not flowing from the reservoir to the brew basket, check the spring loaded reservoir connector and make sure it is in the fully extended position. If there is a malfunction caused by a broken piece causing a leak, email HelpfulNinja@sharkninja.com to see if they will warranty the old reservoir or whatever piece that is broken.
If additional help is needed visit: Fix for Leaking Water Reservoir
Open Drip Stop
Post brew cycle, move drip stop toggle to closed position before removing your brewing vessel.
Here is a picture of the drip stop in the open position: Open Drip Stop
Foreign Taste in Product
Your coffee has a plastic taste
Plastic Taste
Pour half of the bottle of rubbing alcohol in the bottom of your brew dispenser. Fill the dispenser with water, leaving room for the rest of the alcohol. Fill the top up with the remaining rubbing alcohol and brew. I recommend leaving the fully brewed hot water/rubbing alcohol mixture sit in the coffee maker for about 10 – 15 minutes before emptying it. Then, you will need to brew about 2-3 pots of additional water until you’re confident that the alcohol is completely diluted from your brewer.
Austin Hefter
55 Reputation
0 Guides authored
USF Tampa, Team S13-G69, Cagle Fall 2017 Member of USF Tampa, Team S13-G69, Cagle Fall 2017
USFT-CAGLE-F17S13G69
4 Members
36 Guides authored
3 Comments
when i press the brew button it only stays on for 45 sec
ken.poling - Reply Share
maybe a little longer when it goes off i press it again as i keep doing that it brews more water un tail it brews all the water
Where the spring loaded reservoir connector is, there is green algea and mold rowing inside of it, we have followed the cleaning instructions 2x it is still there, we cannot figure out how to remove it to scrub it to get rid of it so we can make coffee.
A E - Reply Share
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 38
All Time: 1,842
