Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Roomba does Not Return to Base
When battery is about to die, Roomba fails to return to Home Base.
Roomba was Picked Up and Moved While Cleaning
If Roomba is picked up and moved during a cleaning job, it will not be able to find the Home Base when the “DOCK” button is pressed, unless it is placed facing the Home Base within 6 ft (1.8 m) of the Home Base. To resolve this, unplug the line cord from the Home Base and then plug it back in to ensure that it is fully inserted with a tight fit. Verify that the power indicator on the Home Base starts blinking approximately once every 4 seconds or illuminates solid for approximately 4 seconds and then goes out. This is normal behavior, designed to conserve energy. Ensure there are no Dual Mode Virtual Wall® Barriers or other Home Bases located within 8 ft (2.5 m) of the Home Base. These could cause infrared beam interference. Position the Home Base on a hard, level surface against a wall. Ensure Roomba has a clear path to the Home Base, and that the Home Base is at least 4 ft (1.2 m) from any stairs and that Roomba has a clear path to reach it.
Faulty Battery
The battery may need to be replaced. Follow this guide to replace the battery.
Roomba Fails to Charge
Roomba does not turn on or show any indication of charging.
Faulty Battery
If the charging base is not the problem, the battery may need to be replaced. Follow this guide to replace the battery.
Battery May Be Overheated
Allow Roomba to cool down for at least one hour. Charge Roomba again in a cooler environment.
Charger or Home Base May Be Damaged
Examine the charger or Home Base line cord and look for any damage. If using a charger, plug the charger into an outlet and verify that the power indicator on the charger illuminates solid green. Replace a needed.
Handle is Broken
The handle is noticeably cracked or broken.
Damaged Handle
A handle replacement will be needed. Remove the faceplate and the lower section below the keypad. Using an adequate amount of force, pop the broken handle off and insert the replacement handle. No screws will be needed. The replacement should snap on and off relatively easily.
Roomba is Not Covering Entire Home
Roomba misses sections of your home after completing its cleaning job.
Dirty Window
Wipe the clear window on the robot's top surface using a microfiber or soft cotton cloth that has been lightly dampened with water or a screen cleaning solution.
Edge Clean is Deactivated
If Edge Clean is deactivated, Roomba may not cover your entire floor. To change the setting, open the iRobot HOME App and select Cleaning Preferences ➔ Edge Clean and then toggle Edge Clean on or off.
Dirty Sensors
To clean the floor tracking sensor, turn Roomba over and use a clean, dry microfiber or soft cotton cloth to wipe any debris that has accumulated in the round sensor opening on the right side of the robot's bottom surface. Do not spray cleaning solution directly into the sensor opening.
Inadequate Lighting
Dark or dimly lit rooms can cause problems with the Roombas navigation and coverage. Make sure all rooms covered by the Roomba have adequate lighting.
Cannot Connect to Wi-Fi
When using the iRobot HOME App, you cannot connect Roomba to your home network.
Roomba is not in the Range of the Wi-Fi Network
Ensure Roomba is located within a 10 ft (3 m) radius of the mobile device, and in range of the desired Wi-Fi network.
Mobile Device has a Weak Wi-Fi Signal
If the device does not have a strong Wi-Fi signal, check for sources of interference, such as Bluetooth devices, cordless phones, baby monitors and microwaves. Radio waves used for Wi-Fi also have difficulty penetrating building materials such as steel and concrete. The Home Base® can be placed closer to the router if there is poor Wi-Fi signal strength at the current Home Base location.
Author
with
Vanessa Greyson
471 Reputation
3 Guides authored
USF Tampa, Team 16-3, Blackwell Spring 2017 Member of USF Tampa, Team 16-3, Blackwell Spring 2017
USFT-BLACKWELL-S17S16G3
4 Members
60 Guides authored
32 Comments
Is it possible to have two different I-PHONES programed to start the Roomba 960 remotely?
hoppy5 - Reply Share
Roomba 960 side spinning brushes are not working . Help
Ann Allen - Reply Share
Roomba 960 side spinning brushes wont spin help
The basket full remains on when the basket is empty. Roomba dosen't work with this light illuminated.
Doug Edson - Reply Share
the basket full stops the cleaning even tho its not full
Marilyn Mogensen - Reply Share
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 67
All Time: 37,892
