Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Device Battery Lasts Only A Short Period of Time
When the device runs, the battery dies before factory described time.
Not Charging Completely
If the device is leaving the charging station without a full charge this would cause the battery to die before factory specifications. This may be caused by a schedule or configuration error.
Metal Contacts Aren't Connected While Charging
Although the device may be near the charging station, the metal contacts on device may not be properly touching the charging station contacts. Contacts should be cleaned, and the charging station or contacts should be replaced.
Faulty Battery
The battery could be dead, or can no longer hold a full charge. If it can't hold a charge, it will not be able to charge fully and would need replacement.
Device No Longer Cleans the Floor
The device travels across the floor and doesn't pick up contaminants .
Trash Bin is Full
The trash bin may be full, and can no longer hold any more contaminants. It should be emptied and placed back in contact with trash bin sensor.
Debris Extractor is Stuck
The debris extractor may lose it's tread or may not be rotating. If it can't rotate it will not be able to pick up contaminants on the floor. Debris should be cleaned off the extractor or the extractor may need to be replaced.
The Device Does Not Move
The device turns on to clean but does not move.
Side Wheels are Stuck
The side wheels may have objects twisted around the axle or debris in between the wheel and device housing. This inhibits the wheel from rotating freely. The treads may also be worn out and can lose grip with floor. The wheels may need replacement.
Center Wheel is Stuck
The castor wheel may be stiff and will not rotate, this indicates debris in center wheel housing and which should be removed and cleaned. If the problem persists, there may be a bearing issue and the wheel may need to be replaced.
Device Continually Runs Into the Wall and Doesn't Change Direction
The device moves and cleans but tries to continue forward after running into a wall.
Side Wheel is Stuck
Objects in the wheel could prevent the device from rotating properly by not allowing the wheel to spin freely. The side wheel should be removed and cleaned or if the problem persists, it may need replacement.
Faulty Bump Sensor
The front bumper may not be registering with the sensor. If the sensor doesn't detect contact it will not try and rotate to avoid hitting the wall. The sensor may need replacement.
Audio Notifications No Longer Work
The device no longer creates audio notification or noises as it did after receiving from factory.
Audio Speaker Damaged or Broken
The device audio speaker could be worn out or damaged and no longer working. This could be caused by a faulty speaker or a loose connection to the speaker. The speaker may need replacement.
Ryan Murphy
461 Reputation
4 Guides authored
USF Tampa, Team S13-G5, Cagle Spring 2017 Member of USF Tampa, Team S13-G5, Cagle Spring 2017
USFT-CAGLE-S17S13G5
4 Members
48 Guides authored
6 Comments
My cleaning head is making a rattling noise. I’ve replaced the roller heads, but it still happens. When I remove the dark gray one, it goes away. A problem with the housing for it?
bobnunny - Reply Share
The device is on, but won’t move from a circle. All wheels appear to be clean and moving.
how can I repair?
THERESE PANDL - Reply Share
My Romba 860 displays ERR 5, what does that mean?
flar1usa - Reply Share
It drives around but does not vacuum or wipe with the brush
Michael Updike - Reply Share
I have torment completely apart and put it back together twice before I realized that it was more than just a wiper motor that wasn't working. I bought it used without a manual but it is a Roomba 860 and it drives around like everything is working but just doesn't pick anything up
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 27
All Time: 2,614
