Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Roomba is on, but won't move normally
The robot is on, however it won't move forward, or is spinning in circles.
Object stuck on wheel
It is possible that the Roomba picked up an object while cleaning that wrapped around its wheel and is inhibiting it from moving. Check both wheels to see if anything is stuck on them. Then, manually push the wheels in and out (do not force them to move, they should move fairly easily) and check if the wheels turn without an unusual amount of resistance.
"Circle Dance" error
If the Roomba is spinning in circles, there could be an issue with the bumper sensor. This can lead to a lengthy and technical fix, but further steps can be taken by opening the Roomba and cleaning the sensor as demonstrated by this guide here.
Won't turn on
No matter how many times you press the power button, the Roomba 560 just won’t turn on.
Dead battery
First, you should check to see if the battery is dead. When you press the power button, is there a flashing red light? If you see the flashing red light or don’t see any lights on, place the Roomba on the charging dock. The following will let you know when it’s charged.
  • Green - fully charged
  • Amber - partially discharged
  • Red - nearly discharged
  • Flashing Red - discharged
Battery doesn't hold charge
In spite of hours of charging, the Roomba 560 still dies minutes after turning it on.
Low charge capacity
This tactic will tell the robot to ignore the charging depth and perform a deep charge. To do this:
  1. Hold the power button for 15 seconds.
  2. Charge the Roomba for 16 hours.
  3. If the light is green, let it run on maximum power until it runs out of energy, taking note of any improvements in battery life.
Faulty battery
If the 16 hour reset fails to improve the battery life of the robot, use this guide to replace the battery.
Won't clean anymore
The Roomba seems to be doing an inefficient job and is unable to pick up particles.
Clogged with hair or other debris
If the Roomba seems to not be cleaning well, inspect the bottom for hairs clogging the device, and remove them. Compressed air may also be used to rid the cleaning system of hair. If the problem persists, you may have to disassemble the bottom and replace the fan. A guide for that process may be found here.
Brushes no longer spin
If the Roomba's brushes are unable to spin, or the Roomba is much quieter than usual, then the brushes may need replacing. These brushes can be easily accessed on the underside of the roomba by pressing the two yellow clips on the corners of the green casing and then lifting this casing.
Unusual beeping
The Roomba beeps at me in a specific pattern.
Error codes
The Roomba will tell you something is wrong with a two-tone “uh-oh” sound followed by a series of beeps. The series of beeps correspond to the following issues:
  • 1 beep: Roomba is stuck with a wheel hanging down or Roomba is stuck.
  • 2 Beeps: Roomba's main brushes cannot turn.
  • 5 Beeps: Roomba's side wheel is stuck.
  • 6 Beeps: Roomba's cliff sensors are dirty or Roomba is stuck hanging over a cliff or on a dark surface.
  • 9 Beeps: Roomba's bumper is compressed or the bumper sensor is dirty.
  • 10 Beeps: Roomba’s side wheel is stuck or its bumper is not registering obstacles.
  • 11 Beeps: Roomba's side wheel is stuck or its bumper is not registering obstacles. (Yes, 10 and 11 do in fact mean the same thing.)
The Roomba will also make a 4-tone "dead battery song" when the battery is discharged. Attach the Roomba to its charging base until it is charged.
This list comes straight from iRobot's error code guide, which can be found here.
Many of these issues can be resolved by simply cleaning the unit and manually adjusting any stuck parts. If further repair is needed, please consult various repair guides linked here.
Roomba stuck to the charging dock
The Roomba 560 will not detach from its charging dock when it cleans.
Uneven charging dock surfaces
Try putting the Roomba 560 and its corresponding docking station on firm, level surfaces while letting it charge. If the Roomba still stays connected to the charger when it begins to move/clean, then refer to the next possible issue.
Damaged device base
Have you removed the bottom of the Roomba recently? If so, it is possible the machine was put back together incorrectly. Try checking to see if all of the screws are in tight and correctly and that there are no loose parts. Refer to this guide for help when removing the battery and bottom of the Roomba.
Mairead Blaes
825 Reputation
4 Guides authored
Cal Poly, Team 1-22, Maness Fall 2015 Member of Cal Poly, Team 1-22, Maness Fall 2015
CPSU-MANESS-F15S1G22
4 Members
84 Guides authored
4 Comments
My 560 will not go into docking mode. It runs for at least an hour and then dies random spots. It will dock if I manually push dock. I even bought a new battery and that didn't help it. It's almost like it's something to do with the program not letting it go into docking mode when battery is discharged. Any ideas on a fix?
newob81 - Reply Share
I found this entire document very helpful!!
Grace - Reply Share
I replaced the battery and put on the charger, it flashed the amber light for a while during charging but then flashes red. Will not clean at all. What can I do??
thanks!
Nikki - Reply Share
My old roomba 500 just received a new battery and has been charged for over 24 hours but stops after 20 minutes and 4 beeps, what more can I do?
Anita Hanna - Reply Share
Past 24 Hours: 4
Past 7 Days: 14
Past 30 Days: 79
All Time: 30,969
