Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Device won't turn on
Your mopping device does not move and lights will not turn on
Battery not charged
Plug in device and wait for battery to fully charge before attempting to use. This problem could also be due to a faulty AC adapter. If the light on the AC adapter does not turn on, check the current of AC adapter with a voltmeter. In order to do this, plug the adapter into a power source, turn the voltmeter on, attach the red terminal of the voltmeter to the pin inside the plug of the ac adapter, attach the black terminal of the voltmeter to a ground (any piece of metal), and check for a current. If the voltmeter reads a current, the ac adapter is functional. If not, replace the ac adapter.
Battery no longer holds a charge
Replace battery with this guide
Battery not connected properly
The battery may not be properly connected. Remove the bottom battery panel with a flat-head screwdriver and ensure that the wires are firmly plugged in.
Faulty power button
The power button may be broken or have some kind of obstruction below the surface of the panel. The button may need to be replaced.
Device won't move at all
Your iRobot Braava 380t turns on but will not move
Worn wheel tread
If your iRobot Braava 380t does not move at all, a possible reason is that the wheel tread has worn off. The wheel tread may need to be replaced.
Wheel suspension
If from the side view, you cannot see the wheels of the iRobot, the suspension spring may have failed. If so your iRobot will have trouble moving.
Broken wheel
If your mopping machine will not move it might be because your wheels are broken. Replacing the wheels is a simple procedure.
Faulty wheel motor assembly
The immobility of your device might also be due to a faulty wheel motor. This part can be found online and replaced fairly simply.
Device won’t move normally
Your iRobot moves in an irregular pattern; going in circles, not turning
Faulty Wheel Motor
If the device isn’t turning or is moving in circles, one wheel motor could be burned out.
Wheels jammed
The wheel axles could be jammed with hair or other debris from normal operation. If so, remove debris with tweezers or other tools. If you are still unable to remove the debris, remove wheels to completely clean the wheel-axles assembly.
Mop-head improperly attached
Ensure that the mopping cloth is firmly attached to the cleaning pad and that the cloth is not tangled. Disconnect and reattach the cleaning pad to the iRobot to ensure proper connection.
Navigation cube
Irregular movement may be caused by a malfunctioning navigation cube or if the signal is interrupted. Make sure that no obstructions are in the line of sight of the navigation cube. If there are no obstructions then you may need to replace the navigation cube.
Device making songs
Your iRobot is chirping a short song
Error Codes
Your Braava 380t makes short chirping melodies to let you know of a problem. The tune lets you know what problem you have.
Jon Michael Burmeister
416 Reputation
1 Guide authored
USF Tampa, Team S7-G3, Cagle Spring 2017 Member of USF Tampa, Team S7-G3, Cagle Spring 2017
USFT-CAGLE-S17S7G3
4 Members
12 Guides authored
30 Comments
Unable to open page with error codes 380t model. Charging light stas red it starts then stops tried charger as well as plugging right into the irobot.
marysue lewis - Reply Share
Mine is doing the same the red light stays on won’t charge did you find out how to fix this problem?
little-anne1 - Reply Share
This is the broken URL I think
https://homesupport.irobot.com/app/answe...
Chris - Reply Share
My braava 380t had a malfunction with freezing right after starting with a short beep. I found that was caused by the bottom sensor trouble. All braava series have bottom sensors for detecting floor. It connects to inner small bars moving up and down that shut the light from the photo sensors when it is on the floor. But if the small bars get dust, the photo sensors cannot detect the bars. So I just swept the bust on bars, then it was fixed. The bars are at the both sides of the front part inside of braava. I think the bars easily get bust, so every braavas may have same trouble after two or three years it is purchased. Try to clean the sensor bars!
And I fixed the charging trouble by replacing an electrolytic capacitor on the circuit board. I feel the design of this product is not so good and it has to be improved...
NobuYosh - Reply Share
how did you replace it? where did you get the info? could you help me with this issue?? i have a braava that wont charge with new battery and new charger
Leire Sanchez Martinez - Reply Share
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 51
All Time: 51,765
