[redirect|https://www.ifixit.com/Troubleshooting/i...]
Problem (Symptom)Likely CauseWhat to Check
Won't Turn OnBattery DischargedCharge iPhone for at least 10 minutes
Won't Turn OnFirmware CrashPerform a forced restart to fix firmware crash
Won't Turn OnBad BatteryCheck if iPhone turns on when plugged; battery may be degraded
Speaker IssuesVolume Turned DownTurn up the volume using the button or through the phone's software
Speaker IssuesPhone Case Obstructing SpeakerRemove the case and test the speakers again; remove screen protector if it obstructs the earpiece speaker
Speaker IssuesSoftware GlitchTurn off Bluetooth, perform a forced restart; rule out software issues
Speaker IssuesBroken ReceiverCheck if sound issues are during calls; utilize Apple's service program or follow the iPhone 12 Earpiece Speaker replacement guide (Note: FaceID may be disabled)
Speaker IssuesBroken SpeakerClean speaker holes; if ineffective, follow the iPhone 12 Loudspeaker Replacement guide
Unresponsive ScreenOperating System FreezePerform a force reset
Unresponsive ScreenBroken DigitizerReplace the entire display assembly; follow the iPhone 12 Screen Replacement guide
Text ProblemsSoftware GlitchRestart the phone; reset network settings; toggle iMessage and MMS settings
Text ProblemsNetwork HangupReset network settings; toggle iMessage and MMS settings; contact service provider if necessary
Camera Not WorkingApp MalfunctionUse default camera app; close background applications; restart phone
Camera Not WorkingCamera is ObstructedEnsure the lens is not blocked; clean the lens with a microfiber cloth
Camera Not WorkingSoftware OutdatedUpdate iOS; turn off VoiceOver; fix Flash Desynchronization Glitch; perform DFU reset
Camera Not WorkingBroken Camera ModuleFollow the iPhone 12 Rear-Facing Cameras Replacement guide
Author
with
Austin Blakely
23,462 Reputation
53 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
20 Comments
Iphone12 unable to connect to carrier, how do you trouble shoot for this issue. NONE of the simple fixes work, reset, airplane mode on/off, restart, update software, clean SIM card, etc. Apple said the phone is bad, but did not indicate what part is bad. Now what?
penny - Reply Share
I am currently working getting an iPhone repaired. The problem is the display won’t show anything and there is no visible damage to it at all. I have replaced the battery and when I touch the cover of the display cable it is fairly warm. What could be the issue
Gibson Marshall - Reply Share
Excellent article ! Thanks a ton - it has been a lifesaver for the iPhone ! Especially on the note on what to do if it is a firmware crash.
Raj Kumar S - Reply Share
I have issue with face recognition not working
sanad alshehhi - Reply Share
Como desbloquear un iPhone si me lo encontré en la calle pero esta bloqueado
Smg1 - Reply Share
Past 24 Hours: 7
Past 7 Days: 46
Past 30 Days: 214
All Time: 48,597
