Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Device will not turn on
iHome does not power on.
Power Adapter may be Unplugged
Check the rear of the iHome to see if the (DC 15V 1100mA) input for the power adapter is fully connected. If the adapter is not connected, fully remove the adapter and replace it into the input.
Batteries May Need to be Replaced
Flip the device over and remove the battery tray cover. Remove and Replace the old batteries with new batteries. Replace the battery tray cover.
Power Adapter is Broken
To check if the adapter has gone bad. Remove the backup batteries and plug the adapter back into the device. If it does not turn on, replace the power adapter.
Device will Not Play Music
When the device is on, music will not play.
The Volume could be Turned Down
The volume may be turned down on either iPod or the iHome. Try turning the volume button up on both the iPod and the iHome.
iPod is disconnected
If the iPod will not connect, disconnect and then reconnect the iPod back to the dock. If the iPod fails to reconnect then look at the subheading labeled [iPod Will Not Connect When Docked]
Speaker Could be Busted
If the iPod is connected and sound will not come out of the speaker than the speaker might be busted. You will need to replace the speakers in the iHome and then reconnect the iPod.
Device Does Not Respond to Buttons or Scroll Wheels
If the buttons or scroll wheel stops working; Replace the buttons or the Scroll wheel.
Unresponsive Scroll Wheels
When using the “Volume”, or “Set +/-“ wheel and they do not respond, you may need to replace them using the [Scroll Wheel Repair Guide].
Buttons are Broken
When using the iHome buttons and they do not respond, they could have a connection issue. You may have to replace the buttons on the device using the [Button Repair Guide].
The iPod fits onto the adapter but it does not connect to the iHome.
iPod is messed up
If the iPod fails to connect, then try to connect a known working iPod to the Dock. The problem may be with the current iPod and not the iHome. If the known iPod works, replace it with your old one.
The Adapter May be Broken
If the iHome has been dropped or you have dropped something on the iHome, the adapter could be broken and will need to be replaced using the [Adapter Repair Guide].
Radio Only Plays Static
When switched to the radio setting, the sound is mostly static or fails to make noise.
The Antenna Could be in Bad Reception
If the device is overly muffled, consider moving your device over towards a window, or make sure your antenna is fully stretched out as this can improve your signal quality.
Antenna Could be Broken
The antenna could be disconnected from your device or the wire damaged, if this is the case, you may need to replace the wire or resolder it to its board.
0 Comments
Past 24 Hours: 3
Past 7 Days: 9
Past 30 Days: 41
All Time: 1,217
