Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
eufy RoboVac 11 Does Not Turn On
eufy? eufy??? You there?
Charging contacts are dirty
The best way to combat this issue is to take a cotton swab or a facial tissue to wipe off the metal contacts on the bottom of your eufy.
eufy RoboVac 11 is not docking properly
Make sure that the RoboVac and the charging base are in the same room, and that the base is not on a dark-colored surface or high-pile carpet. There shouldn't be any obstacles within 1m/3ft to the right and left side and 2m/6ft from the front.
The battery is not plugged in properly
If none of the above seem to be helping, there may be a problem with the battery. The battery compartment is on the bottom of the device and will need to be opened up with a screwdriver. Check to see if the battery is connected to the wire coming from the floor of the compartment.
Battery compartment needs cleaning
The answer to this problem may just be that the battery compartment may be clogged with debris. The battery compartment is on the bottom of the device and will need to be opened up with a screwdriver. To properly clean the compartment, it may be worth it to grab the pre-existing cleaning tool that is provided with the device. If the cleaning tool is not readily available, a cotton swab or a facial tissue will work equally well. Clean the chassis and the battery itself for the best results.
Battery needs replacement
If all else fails you may want to replace the battery.
Rolling brush no longer spins
Yep. Still dirty.
The rolling brush needs to be cleaned and detangled
Just like life, sometimes fixing a problem just takes a little cleaning. To properly clean the compartment it may be worth it to grab the cleaning tool that comes with the device. If the cleaning tool is not readily available, a cotton swab or a facial tissue will work equally well. Check to see if the parts of the brush where the brush sits in the compartment are free of dirt and hair.
The rolling brush compartment is dirty
If the problem persists, there may be an article of trash in the compartment blocking movement. Open up the compartment guard and remove the brush. Remove any big objects that may be stuck.
Roller brush and its guard were installed incorrectly
It may be worth ensuring that the brush and the guard are installed correctly. When installing the wheel, you will want to verify that the right side of the roller brush is going into the hole on the side. For the guard make sure you hear a satisfying click when pressing it back in.
Rolling brush needs replacement
Over time, the fine brushes will be bent and damaged. The wipers could be broken or ripped as well. Your eufy should have come with a replacement which you can use to easily replace the old ones. Remove the guard and the old brush and replace it with a new one.
Rolling brush motor needs replacement
 It may be worth just replacing the brush motor if all else fails. Find out how in our Brush Replacement guide.
Side brushes do not collect debris correctly
Side brushes are bent or don't spin
Side brushes need to be cleaned and detangled
Hair and other debris will often get wrapped around the side brushes and hinder its movement. The easiest way to remove this clutter is to take the brush piece off of its peg, remove all the hair, and use a cotton swab to wipe away the dirt around it.
Side brush connection point needs tightening
There is a small screw at the very center of each side brush. If it is loose or missing the side brushes will not spin properly. Once you have located the screw, use a screwdriver to tighten it.
Side brushes need replacement
Over time, the side brushes will be bent, frayed and otherwise damaged. Your eufy should have come with a few replacements which you can use to easily replace the old ones. Firmly pull up on the fibers of the brush and it should pop off. Simply snap a new brush into place and it is ready to go.
Side brush motors need replacement
If none of the above have fixed your side brush problems, visit replacing the side brush motor.
Side wheels do not have as much movement as before
The eufy either moves incorrectly or not at all.
Wheels need to be detangled and cleaned
These wheels are hard to really get into, so just clean them as much as you can first without breaking into the RoboVac. Use tweezers to extract the hair. Use a compressed air duster to clear out the rest of the wheel housing as much as possible.
Movement wheels need replacement
If a basic cleaning doesn't fix it, you may need to replace the wheel itself.
Movement wheel motors need to be replaced
If replacing the wheel doesn't work, you may need to replace the motor.
Swivel wheel no longer swivels or wheels
The swivel wheel can get jammed, causing unwanted resistance to movement.
The wheel is jammed by hair, dirt or other clutter
This wheel is in the front of the RoboVac and can get clogged with hair. Use the pointy end of the metal spudger to pop the wheel from its housing. Remove the hair from the wheel and its housing. Clean both parts with a cotton swab to remove the dirt and dust. Simply snap the wheel back into the housing when you are done.
The wheel housing is too dirty
There could be debris beneath the housing preventing its movement. Follow the replace the swivel wheel guide to take out the swivel wheel housing. Clean the housing with a cotton swab or compressed air. Then put the housing back.
The wheel housing is broken and needs to be replaced
If cleaning the wheel housing does not work, you may need to replace the swivel wheel.
Josh Mecham
51 Reputation
0 Guides authored
36 Comments
It keeps circleing and not moving forward
Andrea - Reply Share
I replaced the battery, cleaned the wheels the brushes and it wants to start, rolls once and stops again. Please help
thunderxye - Reply Share
Same as mine. Did you manage to get it to work?
peter sandford - Reply Share
Brand new but will only goa few inches and stops
Cindie Kristoff - Reply Share
Can someone help me? New in February thos year but has never gone but a few inches forward. Have checked everything on it but still won't move! I'm ready to send back and get a refund, if noone can help! Very frustrating!!
Past 24 Hours: 0
Past 7 Days: 18
Past 30 Days: 83
All Time: 20,850
