Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Failure to turn on
You have trouble turning the device on
Faulty Power Adapter
Make sure the power adapter is plugged into the wall and the charging light is glowing on the Zoom Q8 Recorder.
Faulty Battery
If the power adapter and the light for the battery being charged is on try replacing the battery with and new one and see if it works. If it doesn't work and its not the charging adapter or battery then it is the wiring of the device.
Faulty Power Button
If the power adapter and the battery have been replaced and the device is still not turning on. The power buttons could not be working. To check you will need to open of the device and make sure the power button is clicking down on the appropriate spot. Also make sure the wiring to the power buttons are connected.
Failure to turn on the screen
You have problems with the camera
Faulty Camera
Check to make sure the screen is on. Also make sure the device is fully charged and the battery is not dead. If these two are working and the camera is on the camera is broken and must be replaced.
Faulty Wiring
If it is not the camera. It must be an electrical problem on the mother board of the device.
You will need to open of the device and take a look to see if it is a wire causing the problem or the mother board itself.
Faulty Recording Buttons
If both the camera and the wiring in the device are good. It could be the recording buttons. You will need to open the device and make sure the button is not broken, hitting the right spot, and the wiring is all good.
Failure to record audio
You are having problem recording sound
Faulty Microphone
Take a video with the device and make sure it is recording. After the recording test the video on your computer to make sure the audio recorder. If it does not capture any sound their must be something wrong with the microphone and they must be replaced.
Faulty wiring
If the microphones have been replaced it could be a problem with wiring and the connections to the mother board of the device. You will need to open of the device and make sure that the connections between the microphone and the mother board is good.
Author
with
Isaac
1 Reputation
0 Guides authored
6 Comments
Hello
my zoom q8 display the microphone on the screen, how do I fix it? it only records sound but no videos.
rsalles770 - Reply Share
Hi. I just plugged in a stereo lead from a Zoom H6 into the xy side socket and selected audio only recording and monitored through the Q8 headphone socket but the signal was very high so stopped the playback, the Q8 now has a horrible noise through all inputs as if the signal blew up the audio circut. No new lead or off/on has reset it. What have I done? :-(
glennroche - Reply Share
My zoom 8 audio is distorted what is the correct settings and is there any way to stop the audio being compressed?
Frances Kappelle - Reply Share
how do i open the devise to check power button
billsogreen - Reply Share
my mikes have come loose on Q8 video capsule i was trying to put them to the centre. have i broken them or can they be re attacjed
regards john swan OAM
swanjohn001@gmail.com. regards and stay safe
john swan - Reply Share
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 35
All Time: 4,428
